A/C Compressor Clutch Engaged All The Time??? HELP!
Old 04-11-2012, 10:54 AM
PL_RACER's Avatar
Default A/C Compressor Clutch Engaged All The Time??? HELP!
Alright guys so i bought this car used, ac never worked neighter did the fans, so i replaced the ac compressor with a new one, filled the refrigerant and is at 30-35psi which is right where it should be, both fans automatically kicked on while filling it, and ac compressor engaged, nice cold air inside the car, i press the ac button off and turn the heat on, but my ac compressor clutch is still engaged? ir does not shut off, and my fans costantly are running unless i take out the keys., checked the fuses and their good, any ideas would be greatly appreciated this is a 2006 Civic Dx Coupe Manual.
P.S. if i unplug the ac compressor, my rad fan never goes on and car never over heats.
Old 04-12-2012, 08:57 AM
JamesB1985's Avatar
Default Re: A/C Compressor Clutch Engaged All The Time??? HELP!
Check the compressor clutch relay if possible and see if its functioning properly.
Old 04-13-2012, 06:15 PM
PL_RACER's Avatar
yah i checked the relay and even swapped it with another one, same problem, any other ideas?
Old 04-13-2012, 06:39 PM
integra15's Avatar
Is it set on defrost? The compressor turns the ac on automatically if it is, even if the button is not lit on the ac button.
Old 04-15-2012, 02:55 AM
PL_RACER's Avatar
Nope not set on defrost, just set on the front vents, tried even on feet still Ac compressor is on, and usually a Ac compressor should go on and then shut off every 20seconds or so mine is constantly on
Old 04-16-2012, 01:20 PM
PL_RACER's Avatar
Any other ideas guys? Is it safe to drive it like this without doing any harm to the Ac compressor?
Old 04-17-2012, 04:14 PM
motegicivic's Avatar
Did you charge it yourself with a retail kit?
If it is always engaged there is a good chance it is overcharged.
Old 07-24-2012, 07:20 PM
heraldo's Avatar
Is it overfilled? That can cause it to run more I think.
TXMAG
07-11-2014 03:48 PM
bradybunch2101
10-22-2012 04:38 AM
SIR 1.6
08-01-2012 05:23 AM
Civic Racer X 7
08-08-2007 05:15 PM
adan CRX
11-26-2003 08:41 AM
Quick Reply: A/C Compressor Clutch Engaged All The Time??? HELP!
