Old 03-31-2015, 08:04 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Honda Accord Brake Guides
Print Wikipost
BrakeExpert's Brake Chart Thread - Civic Brake Upgrades for EF, EG, EK and Integras
Old 02-05-2013, 04:14 PM
  #251
jdmoptions's Avatar
Default Re: BrakeExpert's Brake Chart Thread - Civic Brake Upgrades for EF, EG, EK and Integr
AH Just found your info on brakes
Excellent Guide
Thanks.
Old 02-08-2013, 02:48 AM
  #252
kulo's Avatar
Will mf10l 15 clear s2000 caliper?
Old 02-21-2013, 08:53 AM
  #253
sk8shorty012's Avatar
Originally Posted by fitseries3
how about upgrading from single piston to dual?
IIRC, the Legend dual piston caliper actually has LESS total piston area than the single piston in the ITR caliper. Only reason for getting the Legend caliper would be for "modulation" and possibly better pad wear characteristics. Otherwise, technically the ITR caliper has more braking force.
Old 02-21-2013, 09:23 AM
  #254
BrakeExpert's Avatar
Holy crap if it's not THE MAN. Whats up dude, havent heard from ya in forever.
Old 02-21-2013, 11:18 AM
  #255
Haha what's up Mike! Yeah, it's been a while. After the civic got broken into, salvaged and sold I lost interest in the forums. I JUST recently started posting again, but it's been at least a year or two.
Old 02-25-2013, 07:12 PM
  #256
nh0hatch's Avatar
Quick question, has anyone ran into the problem with the 17CL15VN ITR caliper/piston being a 54MM instead of a 57MM? I'm trying to find a rebuild kit for the caliper, now I'm stuck..any suggestions?
Old 02-25-2013, 07:51 PM
  #257
redflaredcrx90's Avatar
has anyone used the rsx type s caliper on a gsr/ ls set up
Old 02-26-2013, 12:42 AM
  #258
a.k.a. Komodo
Kozy.'s Avatar
Or more rear bias...
Old 02-26-2013, 08:36 AM
  #259
#1 Super Guy
94eg!'s Avatar
You recall incorrectly:
Integra 57mm = 2551.8mm/sq
Legend 38/43mm = 2586.3mm/sq
Perhaps you're thinking of NSX calipers.
NA2 34/40mm = 2196.2mm/sq
NA1 36/40mm = 2306.1mm/sq
Old 02-26-2013, 09:30 AM
  #260
Perhaps it was NSX. Either way, with the Legend calipers you are only netting a 1.35% increase in braking force (assuming everything else held constant).
Pretty darn close IMO.
Old 02-26-2013, 09:42 AM
  #261
BiggieBert's Avatar
same part number as ep3 rear caliper....
Old 03-03-2013, 02:54 AM
  #262
Tkrizz's Avatar
Does anyone know if a 94-97 Integra RS master cylinder will bolt up to a DA non abs brake booster?
Old 03-05-2013, 11:42 AM
  #263
Recktek's Avatar
I was reading through the post to try and figure out if DC rear discs would fit on my Ek Ex or it i need to change some stuff out and this part throw me for a loop
"90-01 Integras (except the Type-R) and 88-00 Civics with rear disc brakes are all interchangeable onto any EK, EG, EF, DA, and DC Chassis."
I know I'm not the first person to ask it and yes i have looked around and found nothing that fits what im looking for mostly just drum to disc conversions
Can someone help
Old 03-05-2013, 03:13 PM
  #264
fitseries3's Avatar
really? is it that hard to understand?
let me break it down for you....
90-01 = 1990, 91, 92, 93, 94, 95, 96, 97, 98, 99, 2000 integras AND/OR civics are ALL INTERCHANGEABLE
this means you can take rear disks off any integra OR civic that has them and they will work on ANY other civic OR integra in that year range.
how hard was that to understand?
Old 03-05-2013, 04:32 PM
  #265
BiggieBert's Avatar
lol ^
Old 03-24-2013, 02:06 PM
  #266
drenchi's Avatar
Good day. Does anybody know if its ok to use 15cl calipers and pistons on a 17cl14vn brake
system? Its currently my set up and i'm worried it would cause trouble in the future.
Old 04-05-2013, 02:13 PM
  #267
digitally_remastered's Avatar
ok so im planning to go with this setup,
03 acura cl front calipers/brackets/pads ands 96 prelude vtec rotors with centering rings.
now the question. ive read deep into your threads, one one of them states for this particular setup you need to grind 4.7mm off the mounting surface of the bracket where it bolts to the knuckle mounting tabs.
just trying to make sure i have the right information before i attempt this.
Old 04-13-2013, 01:17 PM
  #268
delsoldean4's Avatar
So I have a 95 Del Sol S and would like rear disk. Could i just take the rear set up of the SI and bolt it in with no mod needed?
Old 04-23-2013, 01:13 PM
  #269
fiveOHthreePDX's Avatar
Excellent post and very valuable information. Will definitely be utilizing this as I plan to upgrade my brake setup soon on the Ek Hatch. Bump
Old 04-26-2013, 06:29 PM
  #270
jsinher3's Avatar
hey im doing 97 accord v6 calipers bbk upgrade on my 91 civic dx i will be using 91 civic ex spindles, and mini rotors it didnt came with the 23t brackets but with 26t brackets instead, i think... will that set up cause problems , should i invest in the 23t brackets and if so where can i get them, or anything else for that matter? btw i already have a 15/16 mc and the proper pp valve also..
Old 05-02-2013, 10:13 AM
  #271
Steveeghatch's Avatar
dont know if this has been answered or not! but ive heard that 97-01 Honda crv and ITR front calipers are the same?? is that true??
Old 05-02-2013, 11:35 AM
  #272
BiggieBert's Avatar
go to an online honda parts dealer and in another tab an acura parts dealer. see if part numbers match. then post your results.
Old 05-02-2013, 11:42 AM
  #273
thanks, just did, part number for factory are not the same but honda and acura remanifactured are the same numbers!! i guess ill just get CRV front calipers off a wrecked one
Old 05-03-2013, 12:08 PM
  #274
HRsi-dan's Avatar
Any follow-up on the S2G60 set-up? You (BrakeExpert) had mentioned that there were some changes to the setup. I have the parts available to me to do this, just want some extra clarificaiton.
Old 05-06-2013, 12:46 PM
  #275
paintedrock's Avatar
sticky the man good thread
Quick Reply: BrakeExpert's Brake Chart Thread - Civic Brake Upgrades for EF, EG, EK and Integras
