Super Quiet 3in exhaust on CRX
Old 03-18-2012, 11:37 AM
914Racer's Avatar
Default Super Quiet 3in exhaust on CRX
http://www.youtube.com/watch?v=LfBNr...ature=youtu.be
Built this Full 3in exhaust for my CRX. It is super quiet, does not drone at all. Does not sound like most fart can sounding exhaust systems. The car almost sounds stock until you get on the gas hard. Most of what you hear is intake noise. (yeah I know the damn bird is louder than the car)
Old 03-18-2012, 11:42 AM
josephcmiller2's Avatar
Default Re: Super Quiet 3in exhaust on CRX
What's your engine build and please give details on the exhaust?
Old 03-18-2012, 11:52 AM
914Racer's Avatar
http://ef-honda.com/main/viewtopic.php?t=47899
You can see details here.
For reference, it is a mild GSR build. 3in stainless exhaust, VtecKidd header, etc. The muffler is a Magnaflow 3in inlet and outlet. Its the biggest muffler they sell.
http://www.magnaflow.com/02product/s...e=main&id=9440
Although its huge, it really doesn't weight that much. I was kinda surprised. I have a single 3in resonator in line. It is probably 4in max and pretty short. I had it laying around. Thought I might have to replace it with something bigger, but there is no need.
Old 03-19-2012, 06:48 AM
gutted-dx's Avatar
Cars sounds great! I miss my crx with a VRS pipe kit and a Magnaflow, always loved the sound of it.
Old 03-19-2012, 08:06 AM
Twin Cam's Avatar
Wow! Insanely quiet. Nice build man.
Old 03-19-2012, 09:06 AM
Cynical 1's Avatar
doesn't sound that quiet to me...
Old 03-19-2012, 11:33 AM
914Racer's Avatar
It is louder than stock. But compared to almost all the aftermarket exhaust I have heard to date, this one sounds better than all of those and it is quiet. There is no drone inside, and non of that 'blatty" sound you hear on so many Hondas.
Old 03-19-2012, 07:38 PM
1998GsRIntegra's Avatar
Very quiet until you get on it. Nice job.
Old 03-19-2012, 11:50 PM
tianporn's Avatar
How does the 3 inch exhaust system feel in terms of power? I guess you didn't have a previous setup you can compare against...
Old 03-20-2012, 03:51 AM
Ek Forever y0!
Libertariat's Avatar
Catalytic converter? It would be even quieter if you add one of those if it doesn't have one.
@Tianporn: Pretty well every engine dyno'd upgrading to a 3" exhaust gained power on all parts of the power band.
The gain from 2.5" -> 3" might be 3-5whp across the entire band, but you generally pay for it in decibels
Old 03-20-2012, 05:24 AM
914Racer's Avatar
This is the reason I built this exhaust. I was going to prove that you could have a full 3in exhaust and not have to deal with the noise. I have succeeded. As for the cat, don't have one, and no it won't make any difference in the noise. A cat is not a muffler it is a cat. If you want a car quieter you HAVE to increase the volume of the exhaust. Look at a stock S2000 or any other stock Honda. The Muffler is HUGE. Just as in the case of my muffler. The thing pretty much fills up the space below the spare tire well. The Magnaflow I put on has a 22in long case. Most of these aftermarket exhausts come with a 14in long muffler. That is why most of them sound like ***.
As for power levels. I bought the car with a blown engine and have nothing to compare to. However down low the engine feels light years better than a friends LS swap in an EF. My other car is a turbo D and this CRX has a different personality, so its hard to compare.
Old 03-20-2012, 06:25 AM
gutted-dx's Avatar
A cat would for sure quiet it down more. Its main point is to restrict exhaust till it heats up and can burn off excessive fuel.
Old 03-20-2012, 07:57 AM
Ek Forever y0!
Catalytic converters are really simple, they do not reduce power by much (if any) and they seriously tone down the noise and clean up the fumes.
A 300cell metal core cat will probably flow better than a test pipe, clean it up both in sound and fumes.
I've seen dyno comparisons with and without cats, and the difference is like 1-2whp and usually it affects one end of the dyno more than the other. Like you might gain 2whp top end and lose 2whp bottom end of the dyno graph.
They definitely have a big impact on noise reduction.
Old 03-20-2012, 10:03 AM
914Racer's Avatar
A cat will do nothing for sounds attenuation. That comes from a Ford Engineer. I have never seen a cat change the tone of a vehicle by any appreciable amount. I am not worried about the HP loss, I realize how well new cats flow. I am not opposed to a cat, I just don't have one and won't be adding one, unless I move to an area that has inspections.
I am happy with the way the car sounds now. Not looking to change anything else. If I wanted it even quieter, I would get a long Magnaflow 6in round muffler and put it in the tunnel in place of the resonator. But I don't think this install warrants that as it doesn't drone, nor is it loud until you get on it hard, (and most of that is intake noise anyways)
Old 03-20-2012, 10:16 AM
Ek Forever y0!
I agree, it sounds good, but I'm not sure the "super quiet" title is appropriate either. It's definitely a good sound and clearly audible.
Old 03-21-2012, 07:22 AM
unusual71's Avatar
usually with a cat you lose like 1% power up top and gain 1% down low due to the exhaust building pressure a little quicker. They do quiet it down a touch though, not sure why you dont agree.
Old 03-21-2012, 11:35 AM
nealnanoHX's Avatar
A cat will 100% make any car's exhaust quieter. Good sounding 3 inch exhaust though for sure. I would leave it as is.
Old 03-26-2012, 02:26 AM
peter_b16's Avatar
sounds as quiet as my coated ebay exhaust system..but its 2.5in..that 3in exhaust is quiet and looks great!!
RexShop
02-02-2008 04:51 AM
Ding
24
10-24-2005 11:28 AM
HondaRacer32
01-21-2004 06:55 PM
Legacy_CPA
06-04-2002 02:15 PM
Quick Reply: Super Quiet 3in exhaust on CRX
