1999 honda civic help - oil in the overflow tank
Old 06-06-2012, 06:00 PM
  #26
Grandpawmike's Avatar
Default Re: 1999 civic intermitten starting problem???
holding the pedal all the way down is "clear flood mode". check your injectors for leaks. lemme guess, happens on cold starts, but hot starts ok?
Old 06-06-2012, 07:39 PM
  #27
ACinema's Avatar
Had the same problem. Replaced the dizzy half a year ago, but replaced the dizzy again and my starting issue was fixed.
Old 06-07-2012, 07:11 PM
  #28
jsteezy1290's Avatar
it does the hard start hot or cold doesnt matter
Old 06-07-2012, 07:12 PM
  #29
Default Re: 1999 honda civic help - oil in the overflow tank
why would it be head gasket
Old 06-07-2012, 07:14 PM
  #30
Default Cooling fan not working
the other day i noticed the temp was getting up and was still climbing so i shut it off and noticed the cooling fans were not coming on , so i ran wires from the fan to the battery and it worked.. so i replaced both coolant temp sensors and thermostate and still nothing ..
Old 06-07-2012, 07:15 PM
  #31
Former User's Avatar
How do you think engine oil got into the reservoir and on the radiator cap?
Old 06-07-2012, 07:26 PM
  #32
was not on the raidator cap.
Old 06-07-2012, 07:32 PM
  #33
Loss of power and oil in the reservoir = run tests for blown head gasket
Nothing you have said so far rules out this obvious potential diagnosis.
Old 06-07-2012, 07:35 PM
  #34
just hoping its not ..
Old 06-07-2012, 07:37 PM
  #35
Do you want to know what is wrong with your engine? If so, stop hoping and start doing some tests that will confirm or refute the blown head gasket diagnosis.
Old 06-07-2012, 08:00 PM
  #36
94redex's Avatar
hoping its not going to do u any good it sure sounds like a head gasket.
Old 06-07-2012, 08:42 PM
  #37
Default Re: Cooling fan not working
Three related threads merged.
Did you bleed the cooling system?
Overheating is another sign of a blown head gasket.
Old 06-07-2012, 09:15 PM
  #38
anothersickhatch's Avatar
It is. Constant overheating, loss of power, trouble starting, oil in the radiator overflow tank, and adjusting your timing to the most advanced possible position and driving around. That's 5 for 5 for a blown head gasket.
Old 06-08-2012, 06:17 AM
  #39
Update.. I flushed the coolant system after I put the sensors and thermostat in and now the temp gauge stays below the half mark, but the fan still does not kick on..i figured the oil could be in there by a previous problem and timing was off but I didn't know.. I just never had a blown head gasket on a honda so I didn't know what the symptoms were, my mechanic said since its not over heating anymore
emagdnLm
10
08-30-2011 04:26 PM
wilfong_13
01-31-2008 09:55 AM
siresword
10-25-2007 12:28 PM
whitecrx
03-02-2005 08:03 PM
92jdmhatch
10
12-28-2004 07:53 PM
Quick Reply: 1999 honda civic help - oil in the overflow tank
