Ignite E98 vs Ignite 114
#26
Re: Ignite E98 vs Ignite 114
What is the ethanol percentage/content on the 114? I tuned on pump E85 last year, and would just like the piece of mind when it comes to fueling consistency. I am already planning a switch to a dedicated fuel supply like this, just wondering what form will keep my current power level still available with my current pump/injector combo. I am not ready to switch the fuel system up yet, but will be looking at that possibility later in the summer.
#27
#30
#32
I've been playing around with different mixtures(leaded and unleaded) of ethanol and won't say much about it yet but so far i've made more power with a blended E85 over e98..
#33
Is there much "safety factor" in the tune on the ingnite 114. Compared to some of the higher octain racegas's? Like c16 or c22
#35
FYI: I just got a quote from the ONLY distributor here in CT
E98 $500/55gal
114 $540/55gal
Both prices are picked up prices. Not shipped....
I hate this ****ing state....
E98 $500/55gal
114 $540/55gal
#36
years ago i did a C16 vs Q16 vs E98 test and it was like 40~45hp gain from C - Q and 60hp gain from Q - E.. same boost for all fuels (45psi) So in total E98 made 100hp more then C16... The E98 made same power as Q16 with about 5~6lb less boost..
holly hell thats kick *** nice
im going too be running my 200 shot g23 on e98 getting the fresh barrell today at alot cheaper than the prices listed above....
#38
If anyone is looking for E-98 by the drum call Glacial Plains Co-op in Benson Mn. Phone number is 800-697-5311 ask for Joel james. They are a ethanol plant. I work very close with Joel and his ethanol is very consistant. He will ship drums of this fuel to all 50 states. I think you will find it alot cheaper than ignite brand. I also have the formula to blend E-98 to E-85 the correct way.
#40
#42
#43
I have always found the most power up over 12.0 with E85-98, but my headgaskets have been disagreeing with that statement as of late.
#45
My safety factor is running sub 11.0:1 (gas scale) afrs when dialing in. If you hit a lean spot or run out of fuel, it takes alot to get it up over 12.5:1. With your leaner fuels, you are pretty much always running around the 12.0 range without much room to go up or down without losing power.
#46
BTW. Have never used e85 or any of the race blends, just trying to find some info on it from people that has used it. Seen that t1 has some info on and i am fixing to read it.
#47
Got my order!
1 barrel of 114, it's for a customer, and 3 barrels of E98. 2 for me and one for a Evo buddy.
