Where is the PCV valve in civic 98 lx?
1998 Honda Civic LX, 195k
I want to clean the air induction system but I have a question, where is the PCV valve?, What are the points to be checked in the system?
thanks
thanks
Re: Where is the PCV valve in civic 98 lx?
PCV valve is under the intake manifold. Easier to see from under the car. Connected to a black metal box looking thing.
u are very mistaken on the fuel rail? what car are u talking about.. not a honda i've worked on has ever had a pcv valve on the rail
Its underneath ur intake manifold best way to get to it is from the bottom
here's the DIY i used when i changed mine for the first time
http://www.diymyhonda.com/civic/gara...acement-d16y7/
You are mistaken.
As said the PCV is a black box under the IM, just above the oil filter.
Do it at the same as you change the oil, it makes it a lot easier without the filter there.
But, you may try from up top, that is how I did mine. The crappy y7 IM will really make you mad doing this, so get ready to swear.....
