disc brake conversion on 1st gen crv?
Old 01-25-2012, 10:15 AM
DominicanFlow's Avatar
Icon2 disc brake conversion on 1st gen crv?
hey guys i was wonder has anyone done a rear disc brake conversion on a 1st gen. ive bin looking around and havent found any threads on that. can any one help with parts or a thread?
Ps; also would like to recieve info on where i could get the edm front bumper.
Old 01-25-2012, 10:22 AM
Default Re: disc brake conversion on 1st gen crv?
ttttttt
Old 01-25-2012, 11:15 AM
LDForget's Avatar
You can get the EDM front bumper from honda. A search will give you the part number.
As for the disc brake conversion, ive been thinking the same thing. I remember somewhere on jdmrides.ca someone putting crv drum brakes on their civic just to have something different, but still a 5 lug upgrade. It would take some searching to find it.
::EDIT::
I should add, the point i was getting at is if the crv drum brakes can be put on a civic, and 5 bolt integra disc brakes can be put on a civic, then somehow the integra disc brakes should be able to go on a crv.
Old 01-25-2012, 01:23 PM
qwrty's Avatar
you could either use prelude or legend rear disc set up, the only problem is that you have to
fabricate your caliper brackets, so basically any 5 lug rear disc set up just make that bracket
and your good to go! ive been wanting to do this set up but cant get the time to dabble on this,
so good luck if ever you go through this project...
the guy who did it before quoted me for a price from his machine shop to make the caliper
bracket but we lost contact, thats one of the reason i never got a chance to work on this!
Size:  23.2 KBName:  72fe9862.jpg
Size:  24.7 KBName:  f6ffa2df.jpg
hope this helps..atleast give you an idea..
Old 04-08-2012, 03:14 PM
Danielsb20crx's Avatar
[QUOTE=qwrty;46745128]you could either use prelude or legend rear disc set up, the only problem is that you have to
what they ksports for the crv im getting a set of thoses for my V
hope this helps..atleast give you an idea.w.[/QUOwTE]
Old 04-12-2012, 03:35 AM
el crapitan's Avatar
just out of curiosity, why do you want rear disc?
Old 04-12-2012, 05:19 AM
qwrty's Avatar
for me...honestly-> just for the looks! LOL!!
but hey, ive been using my V on the track and i never had braking problems or may be i dont
need to use that much stopping force since all i do on the road course is go faster!! lol..
Old 04-12-2012, 06:47 PM
drum brakes provide more force than disc. greater contact area.
only drawback really is the inability to dissipate heat, because of confinement. that, and discs are easier to service. and look nicer, of course
Old 04-15-2012, 02:35 PM
The Chazzer's Avatar
I hate drums purely for the increased difficulty to service. That and the look.
In this day and age, there is no reason for a passenger vehicle to have drum brakes.
Old 04-16-2012, 03:49 AM
Seagull Management
94EG8's Avatar
You hardly ever have to service Honda drum brakes, seriously. Rear discs on the other hand require frequent service.
Old 04-16-2012, 03:59 AM
billyb18's Avatar
why not get a 5 lug set up from a jap itr and hand brake cables from a civic si
Old 04-16-2012, 04:26 AM
Seagull Management
94EG8's Avatar
Because of the rear axles. If it was a FWD CR-V that would be a perfectly viable option. Especially when you consider that the front brakes are identical to ITR brakes.
Old 04-26-2012, 10:53 AM
qwrty's Avatar
just to pitch out an idea... how bout gen.2 crvs rear disk set up?? since we're doing a fabrication
of the caliper bracket why not get it from a similar make/model... i really wanted to do this but i
guess i have to source out some parts.... anyone whose in a hurry just give us an update!!!
Old 04-28-2012, 04:34 PM
www.megameet.org's Avatar
So You swap out to discs in the back... Then what? You still need to change the proportioning valve in the front, or the rears are still only going to be what, 20% of your braking force, which = a waste. You would need to get to 40-50% to make it worth it. Will the ctr or itr valve fit like the crv like on a civic? Maybe, but i dont think anyone has actually checked model numbers.
Old 04-28-2012, 05:00 PM
qwrty's Avatar
i think the guy who did the white one used a 40/40 prop valve.....!?!?
i really want this but in my case right now, i dont need it may be later if i feel more comfy pushing
my V on the track/road course but when that happen.. i think my civic would satisfy my speed "fix"
rather using my V.. im just enjoying my V thats why i still bring it more often to the track/road course
and i could haul my bbq grill/smoker on it compared to the civic...LOL!
Old 02-12-2014, 07:37 PM
theycallmedj's Avatar
sorry to revive a old post, but was wondering on this as well, i like the disc look and there soooo much easier to service, im about to do my first drum service in my life, all my vehicles either were sold before they needed service or (for the majority) had rear disc, my eg civic had rear disc with a 40/40 valve, that thing stopped! lol ... one day ill try this
Old 02-13-2014, 07:29 AM
qwrty's Avatar
take a look at 2nd gen Vs....
you could pretty much get all parts from there, as stated before.. all you need is to modify/fabricate
a bracket to hold the calipers, at one point i stripped down one side of the drum brake and just to see
how it could be done...
all we somewhat come up is that after removing the drum brake set, we could leave the back plate and
somewhat drill the brackets from a gen2 crv there.. its somewhat similar since the gen2 has the
rear diff too... compared to the original guys who did the conversion, he used prelude or acura legend...
he once gave me a price on the brackets i think its around 300!?!? but thats 4-5yrs ago...
then never heard from the guy again.. thats why i never got into dabbing this conversion...
good luck on whoever wants to start this again!!
Old 02-13-2014, 03:20 PM
well when im done with my v and bike and have time and money to dab into this, ill be trying it
Old 04-23-2014, 04:48 PM
Skillachie's Avatar
Tried it yet?
Old 05-19-2014, 08:47 AM
i havent...
Old 05-19-2014, 10:44 AM
shermanyang's Avatar
I'm wondering if the 2nd gen CRV's rear brake setup would work?
regardless...once you do it, please do a write up.
Old 07-02-2014, 11:29 AM
Skillachie's Avatar
Wouldn't it be cool if a certain company made brackets readily available to us?
Old 07-02-2014, 09:35 PM
qwrty's Avatar
integra typeR 5 lug trailing arm worked fine! a bit of mods and fab to make the rear diff from
the rt4wd system.. none the less it worked!! i was looking unto the 2nd gen crv since its for
a rt4wd.. also the parts would be easy to source, but didnt have the time and full technical know
how to make a written build for it... good luck on those who will attempt! some guy from the
home land P.I used a 5lug conversion but made the V a FWD...
Old 07-04-2014, 03:08 PM
mrnicolas's Avatar
any pictures of the fab work with the itr rear trailing arms?
Old 02-26-2015, 10:36 AM
Skillachie's Avatar
So can anyone fab up a bracket like this one?
Originally Posted by Del Sol
hubcentric brackets to maintain offset and mount calipers
Quick Reply: disc brake conversion on 1st gen crv?
