Oil Leaking From Valve Cover in a strange spot
Old 01-05-2012, 12:14 PM
Mr.Chow's Avatar
Default Oil Leaking From Valve Cover in a strange spot
So I'm guessing this would be easily fixed by replacing these grommets, but what would cause enough pressure to actually force oil out this way?? I've probably owned around a dozen hondas and have never seen anything quite like this.
Any ideas?
Old 01-05-2012, 12:25 PM
The Grumpiest
grumblemarc's Avatar
Default Re: Oil Leaking From Valve Cover in a strange spot
It's called crankcase pressure. Change the grommets and seals.
Old 01-05-2012, 12:30 PM
Mr.Chow's Avatar
that's what i figured...would a oil catch can prevent this?
Old 01-05-2012, 12:38 PM
Mr.Chow's Avatar
what i ment by that is does a catch can relieve some pressure in the head?
Old 01-05-2012, 12:43 PM
The Grumpiest
I run one of these.
http://www.ebay.com/itm/VENTED-OIL-C...434252&vxp=mtr
Old 01-05-2012, 12:46 PM
cvcrcr99's Avatar
^^Never saw that before. I will have to look into it.
Old 01-05-2012, 12:47 PM
The Grumpiest
He's the only one that makes those.
Old 01-05-2012, 02:02 PM
Hidenplanvew's Avatar
Put some Honda bond on the bottom of the gasket... It how many years old...
Old 01-05-2012, 02:33 PM
hyperblu's Avatar
Wouldn't hurt to change your pcv valve just in case it's not venting properly.
Old 01-06-2012, 08:29 AM
cvcrcr99's Avatar
Yea, I looked into it last night, but couldn't find anything anywhere. I appreciate it!
Old 01-06-2012, 09:32 AM
The Grumpiest
BTW. It does work. All the previous speculation about them in other threads aside.
Old 01-06-2012, 10:11 AM
sde780's Avatar
^ if it were cheaper I'd buy one too for myself...I have the valve cover breather connected to a hose down to the ground and gutted my stock PCV valve and put a hose on that to the ground...no issues for the 12k miles at 235whp
Old 01-06-2012, 10:18 AM
EK9
Dc4LsTeG's Avatar
Never seen that before but seems like a good idea ill prob have to order one thanks for sharing that..so do you still run a catch can with this oil cap?
Old 01-06-2012, 10:19 AM
The Grumpiest
I bet you could probably make something like this easier than you think.
Old 01-06-2012, 10:21 AM
The Grumpiest
I don't but TBH never got around to installing one even though I wanted to. Won't have that option after the build.
Old 01-06-2012, 10:24 AM
EK9
Dc4LsTeG's Avatar
Would you recommend still running a catch can if I were to order that?I have a boosted b18c5 .63 10psi
Old 01-06-2012, 10:32 AM
EK9
Dc4LsTeG's Avatar
I also wont be running stock pcv system or black box will have it blocked off
Old 01-06-2012, 10:33 AM
The Grumpiest
I plan on it. Can't have too much ventilation. I'm removing the PCV system and routing it into the catch can.
Old 01-06-2012, 10:36 AM
EK9
Dc4LsTeG's Avatar
Ok thanks for your input and the link
sde780's Avatar
Catch can if you want to save the environment, open line to the ground if you're gangster
Black box just catches the vapors and drains it back to your oil, I gutted my PCV valve and kept the black box. Some people weld AN fittings on the valve cover and run those to a catch can for further ventilation.
Old 01-06-2012, 10:41 AM
EK9
Dc4LsTeG's Avatar
I know all of that I was asking his personal opinion when it came to how well that oil cap would ventilate the system
Old 01-06-2012, 10:56 AM
sde780's Avatar
You know all that? Then why would you block off the black box? It's just another place to vent your crankcase...
Old 01-06-2012, 10:57 AM
The Grumpiest
Going to be running one of these
http://www.brfittings.com/index.php?...&product_id=82
and one of these
http://www.brfittings.com/index.php?...&product_id=62
to eliminate the whole PCV/blackbox system.
Old 01-06-2012, 11:24 AM
cvcrcr99's Avatar
After seeing that the ebay auction is no longer active, I decided to message the seller. He said that they have been discontinued at this time.
I should have a spare oil cap laying around. I might drill it out and cut up an old, eBay intake filter to see what I can do. Probably won't look as nice, but I'll give it a shot I guess!
Old 01-06-2012, 11:52 AM
H22AFerio's Avatar
It could be a lot of things. As everyone said Start with replacing the PCV Valve if you’re still having the pressure I would suspect rings at well the pressure could be from blow by from worn rings as well. I like running catch cans all on my motors boosted or NA it just keeps all that nasty oil and crankcase gases from being introduced back into the motor.
Quick Reply: Oil Leaking From Valve Cover in a strange spot
