98 Civic Dx Hatchback -- Fuse 31 Keeps blowing. Need help with wiring diagram
Old 12-31-2011, 09:07 PM
  #26
CoolFoolIT's Avatar
Default Re: 98 Civic Dx Hatchback -- Fuse 31 Keeps blowing. Need help with wiring diagram
Dear RonJ@HT,
Would you be able to inform me on how/what/when this circuit works?
are you able to upload the connector?
I am at work right now, but I'll do test tomorrow. Also, I appriciate your help - Thanks!
Old 12-31-2011, 09:21 PM
  #27
CoolFoolIT's Avatar
Hey I found it my self!
May Google be with you!
Old 01-01-2012, 10:35 AM
  #28
Former User's Avatar
Not sure how those^ two diagrams help you.
Here's the detailed fuse 31 circuit:
As you can see from the circuit above, there is only one intermediate connector (C131):
You can also try disconnecting C131 to see whether it prevents fuse 31 from blowing.
Old 01-01-2012, 10:42 AM
  #29
This is the test I wanted you to do:
Originally Posted by RonJ@HT
Have you tried unplugging the main relay to see whether this prevents fuse 31 from blowing?
Did you do this exact test?
Originally Posted by CoolFoolIT
I have Disconected the main relay, all ECU connectors, and all ICU connectors and tested continuity to body ground on the bottom of the fuse slot!
Maybe I did not mention it but with all disconected there is still short to ground on the fuse.
I'm not confident that you did this^ short test correctly. Unplug all three components again, as well as connector C131 (see below), and then crank the engine for 30 seconds to see whether fuse 31 blows. Post the results.
Old 01-14-2012, 09:39 PM
  #30
CoolFoolIT's Avatar
After about 1 week of chasing it, I figured it out.
The engene wiring harness, and the cab wiring harness, connedted so that the Blue/White wire was connected to a ground, (Broun/Black) so it wasn't going to the ECU. No wonder my car only started from the second crank, even if the first wasn't even a full turnover.
Thanks for all Your help!
Bellow if the picture of the plug where it has interfierd with a ground.
Old 10-18-2012, 08:13 PM
  #31
mehran's Avatar
I think my problem has this kind of problem.
its a d16y7 engine and I've changed the Dizzy,mainrelay and it hasnt started.
and i checked my fuse box
and fuses 18,19,20,21 / 29,30,31,32
have no power in them.
and Now i see that 31 needs to be working, but can this mean that my ECM/PCM is bad or my integrated control unit is bad?
fatsalmon15
Audio / Security / Video
04-10-2014 06:44 AM
Hatcheys314
02-22-2010 08:21 PM
danielfleenor
11-17-2009 01:50 PM
Quick Reply: 98 Civic Dx Hatchback -- Fuse 31 Keeps blowing. Need help with wiring diagram
