> Honda Accord (1990 - 2002)
Old 12-04-2011, 11:52 AM   #1
William1991b
Default How to bleed Power steering?
I'm hear a grinding sound when Im turning steering wheel. I replace my power steering hoses. So im thinking air got in it. But im not sure how to bleed it or how to take the air out.
tutorial with a video would be nice =D
William1991b is offline   Reply With Quote
Old 12-04-2011, 05:10 PM   #2
William1991b
Default Re: How to bleed Power steering?
70+ views and noting -_-
Old 12-04-2011, 06:52 PM   #3
6_Speed
Make sure there's adequate PS fluid in the reservoir. Put the car in park, rev the engine to a fast idle (I used 1500 rpm) and turn the wheel from one extreme to the other while avoiding full lock. Do this several times, then return to center and let the car idle normally for a couple of minutes.
Check all the hoses, especially the suction hose (inlet) and make sure they are pushed in far enough and securely clamped.
6_Speed is offline   Reply With Quote
Old 12-04-2011, 07:07 PM   #4
10psiLsEf2
10psiLsEf2's Avatar
Air in the power steering pump/system wouldnt make a grinding noise. MAYBE a whine and stiff steering.
But like mentioned above turn car on hold rpm at around 1500 rpm and turn the wheels all the way left and all the way right back and forth. (dont go to the very max were you feel the rack wana burst lol!
if it doesnt go away id start saving for a new pump.
10psiLsEf2 is offline   Reply With Quote
Old 12-04-2011, 08:15 PM   #5
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Just top the resevoir to the max line and steer the wheel from lock to lock. Doing this will bleed the system.
Usually when it whines, fluids low. Otherwise the pump may be on it's way out.
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 12-04-2011, 08:46 PM   #6
6_Speed
If there is air getting into the inlet, the pump will make a buzzing noise, which gets louder as you turn the wheel. You'll see foam and bubbles in the reservoir as well. Since you replaced the hoses, they should not be a contributor. There is an o-ring in the inlet fitting of the pump that could potentially leak air into the system.
2006, acura, bled, bleed, element, fluids, honda, hose, mdx, pilot, power, steering, strering, tool, william1991b
