Rough idle problem! then dies after it warms up?
Old 11-19-2011, 01:36 AM
01oemTeggy's Avatar
Default Rough idle problem! then dies after it warms up?
have no money to take to a shop anymore... here's a list of what i have in case it contributed...
port and polished
skunk2 valves
skunk2 titanium retainers
ACT stage one clutch
skunk2 stage 2 cams
koyo radiator
tanabe super medallion exhuast
arp head studs
hondata s200 (not installed)
as soon as it warms up it hesistates, bounces between 800-500 rpm then dies... always after it warms up. while the rpm bounces i can tell the lights dim. i can hear a rattle sound (sounds like exhaust) gonna check that soon. will not rev past 4500 rpm. don't think its in limp mode (3500 rpm)
Here's what i've DONE so far.
cleaned iacv
new thermostat
Old 11-19-2011, 01:40 AM
TOO MUCH TORQUE's Avatar
Default Re: Rough idle problem! then dies after it warms up?
air in coolant system causes erratic idle
you also didnt specify your year integra..FITV valve if you got older integra
http://www.team-integra.net/forum/19...your-fitv.html
Old 11-19-2011, 03:42 AM
01oemTeggy's Avatar
2001 integra gsr. i saw that thread and was on my too do list. i tried to bleed out the air but it wouldn't push any bubbles out after awhile so i assumed it bled. i just let it sit there with the radiator cap off for awhile?
Old 11-19-2011, 03:49 AM
g82pGsr's Avatar
Prob a clogged iacv...try cleaning it out
Old 11-19-2011, 04:46 AM
01oemTeggy's Avatar
that was my first thought after thread searching. but as stated in the first post i cleaned it and it only idled a little better =/
Old 11-19-2011, 07:34 AM
g82pGsr's Avatar
Oops didn't see that...clogged cat...could b your prob too
Old 11-19-2011, 08:04 AM
Dannyx321's Avatar
have you gotten it tune after the cams and stuff?
Old 11-19-2011, 02:09 PM
01oemTeggy's Avatar
no haven't had a chance to install the hondata s200 (shop "can't" find it) but i can't tune it till i fix the problem and at least get past 4500 rpm
Old 11-19-2011, 03:14 PM
Dannyx321's Avatar
Guessing its a b series, may want to check if you have vacuum leaks or it might just need a tune.
Old 11-22-2011, 12:12 AM
01oemTeggy's Avatar
gonna check for vacuum leaks asap. trying to get it tuned but got let go at my job and don't have the money for it at the moment...now has 7 codes.
p0172-running rich
p0402-below cat threshold
p0301-cylinder 1 misfire
p0302-cylinder 2 misfire
p0303-cylinder 3 misfire
p0304-cylinder 4 misfire
p01399 - random/mulitple misfires
still troubleshooting one by one when i can. Just did -
VALVE ADJUSTMENT
cleaned iacv
new thermostat
still smells of excess fuel, idles ok but tach bounces between 800-under 500, lights dim when in that range, then dies but starts right back up, won't rev past 4500 rpm.
Old 11-22-2011, 11:18 AM
Hondaman9722's Avatar
Check your fuel pressure regulator may be stuck closed or damaged. if running p0402 it mostlikely your downstream o2 sensor witch if it is bad or shorted to power then ir most likely ur sensor is bad. o2 reads off 0-1 volt if it reads 1(or more) it believes it is running lean then causing you to run rich and p01399 limits your rpm to avoid damage to catalyst
Old 11-22-2011, 11:44 AM
DeeC2's Avatar
make sur all ur plug wires are in the correct place. same with your engine grounds
Old 11-22-2011, 02:08 PM
01oemTeggy's Avatar
defs sounds like it could be it, gonna wait for my friend to get off work and see if he'll let me borrow his 02 sensor to check if thats the problem.
they are all in correct order, however grounds look bad but not sure how they perform, gonna replace all of them just cause
Old 11-22-2011, 03:16 PM
mouab18c1's Avatar
Fix your error codes. What injectors are you running? What ecu are you running? You need a basemap to start the car.
Old 11-22-2011, 05:19 PM
01oemTeggy's Avatar
workingg on fixing the codes. noticed something today, only idles rough when at operating temp anytime before that and it doesn't fluctuate
Stock injectors
Stock oem untouched ecu.
Old 11-22-2011, 05:48 PM
kchungb17a's Avatar
When you borrow your friend's O2 sensor, see if you can borrow his IACV too and see if your problem persists.
The fluctuating idle with no FITV leads me to believe that you have a vacuum leak. Check vacuum level at idle. Should be about 19 in/Hg STEADY. If it's not that, see if you can chase down the vacuum leak. Though that shouldn't cause your car to stall at op temp, just idle rough.
Otherwise, I'd check the fuel pressure.
Should be:
39-46 psi as is.
40-47 psi with vacuum hose removed from regulator and pinched off to prevent vacuum leak.
If all that checks then check each injector's resistance: should be 10-13 ohms.
That's all I got. GL.
Edit: Are you still running the stock GSR intake manifold? Might be that the IAB is stuck open... Not likely but might be worth checking.
Old 11-22-2011, 05:58 PM
TheRealTegger's Avatar
Originally Posted by 01oemTeggy
Stock injectors
But are these the FACTORY ORIGINAL injectors? In other words, did the car leave Suzuka with those particular injectors plugged into its intake manifold?
I ask for a very good reason!
Old 11-22-2011, 06:04 PM
01oemTeggy's Avatar
Originally Posted by TheRealTegger
But are these the FACTORY ORIGINAL injectors? I ask for a VERY good reason!
'm am certainey are! what if they werent?
Old 11-22-2011, 06:05 PM
01oemTeggy's Avatar
gonna check everything asap, i don't have it, shop said it "cracked" and gave me a blox intake manifold
Old 11-22-2011, 06:09 PM
Then they may have been replaced with the wrong ones. And that leads to a P0172. The Honda dealer parts catalog listed the wrong injectors for the '98-'01 GS-R until about Feb/02. Correct part number is 06164-PJ2-000.
Old 11-22-2011, 06:55 PM
kchungb17a's Avatar
If you have a blox manifold then you have no IAB. I've never seen a cracked manifold outside of a severe accident. I would be somewhat suspecting of your shop. Tell them that you want your manifold back. If they resist then start talking tough and mention the B.A.R. You are entitled to receive any replaced parts.
Old 11-22-2011, 07:02 PM
kchungb17a's Avatar
If I'm not mistaken, all B series injectors are 240cc. Yes even ITR. The difference for the 98-01 (possibly 96-01) injectors is that the connector is different, I believe, for OBDII.
There aren't a whole lot of other injectors that will plug straight into your connectors. I'd argue that the P0172 is due to the unburned fuel that is going into the exhaust stream due to all your misfires.
Old 11-22-2011, 07:26 PM
01oemTeggy's Avatar
i'll look into it.
already went to the bar, filed a complaint, the owner went into a coma after food lodged into his throat. (comfirmed) i told em i wanted ALL my parts but the younger brother doesn't know where they are at so i'm stuck. i mentioned i wanted any parts that were good before he went into his "coma"
this makes sense...still waiting to have time to check it out as i work every single day this week due to thanksgiving.
Old 11-22-2011, 08:29 PM
kchungb17a's Avatar
Wow! Good luck man... And Happy Thanksgiving.
BTW, where in CA are you?
Old 11-22-2011, 08:37 PM
mouab18c1's Avatar
Correct all B series OEM injectors are 240 cc. The only differences between obd1 and obd2 are the injector clips.
Since you don't have a wideband I would check for fuel pressure as stated above when the problem usually occurs.
Quick Reply: Rough idle problem! then dies after it warms up?
