Quickie Dyno Comparison - RC440 vs. ID725
#52
Re: Quickie Dyno Comparison - RC440 vs. ID725
For your eye calibration... made today.
Before:
Power: 196,5 PS / 177,6 Nm
B18C6: 2300km engine
Cat: nope
Header: stock EDM
Catback: Apex'i N1
ECU: stock EDM
Intake: stock
After:
Power: 204,4 PS / 180,7 Nm
B18C6: 14000km engine
Cat: JDM 98' Spec-R
Header: stock JDM 98' Spec-R
Catback: Spoon N1
ECU: JDM 98' Spec-R
Intake: stock
Before:
Cat: nope
Header: stock EDM
Catback: Apex'i N1
ECU: stock EDM
Intake: stock
After:
Cat: JDM 98' Spec-R
Catback: Spoon N1
ECU: JDM 98' Spec-R
Intake: stock
#53
who needs a stroker crank when u can buy a set of injectors...
guess i will need to test some rc's against the id's this winter in a controlled environment again and show it takes alot more than upgraded injectors to produce 20+ whp from a n/a setup
#54
Here is another example. Gained 8-9whp
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/bosch-900cc-injectors-vs-rc-550cc-2687802/
#55
One one of my tests that had a similar basis we made 5-6whp over RC 550's by switching to ID 725's.The main cleanliness in the graph along with about 1-2whp gain was from bumping up the fuel pressure from 45 to 60.
This was on a Honda Challenge H2 car making a total of 192whp after the injector swap
#56
^^^these results have been what myself along with many others have seen from extensive testing of the id's vs old rc technology, anywhere between 5 to 10 whp.
the few who claim 15 and 20+ whp gains are not making these gains from swaping injectors alone although they may honestly believe they are lol
if i have the chance this winter i will show u guys what a set of rc 550s will do against the id 725s in the same setup, on the same dyno, back to back on the same day. this will be on a 90x95mm setup which will make around 330whp. the ids will definately gain, but not 20+whp lol
#57
I guess there was just some confusion in the Hungarian HP/PS/KW conversion to American Wheel Horsepower, but nonetheless a gain is a gain so congrats to you Koczeka
#58
Moderator
This makes sense to me. I would love to see another test of before and after dynos. I read nothing but good things from members on here. Cant wait to get me a set.
#59
unless you are measuring AFR at each cylinder you're getting an average value, maybe one injector was coming up a little short and thus the big gain after the swap
Bradstard
08-19-2004 01:58 PM
allm0t0rsir
04-06-2004 01:02 AM
