| Welcome to Honda-Tech! | ||
#1 |
Hey Em2 Peeps,
Just needed the torque specs for the head bolts, im doing my head gasket job next week and i want to be able to give the mechanic the torque specs for the head bolts so there wont be any excuses after the job is done. if anyone can help me out i would gladly appreciate it. another question while im here, is there any torque specs for the cam shaft bridge if that's what its called, i bought a new head and the cam shaft top portion was not torqued down all the way, not sure why but whatever as long as im good to go at the shop. any and all info please help thanks! |
#2 | |
It might've been
1965 Ford Cortina |
+ "d17 head bolt torque" =Quote:
![]() The info is on here too, but the image was missing. |
#3 |
thanks alot IWM Im going to print this out when i go to work!
#4 |
Would these specs work for a 2002 Acura EL 1.7? I need to replace the head gaskets and head bolts. Thanks
#5 |
It might've been
1965 Ford Cortina |
#6 |
Ok perfect thank you!
| Tags |
| 2005, blockpics, bolt, civic, d17, d17a2, gasket, head, honda, hondaheadbolttorquespecs, sequence, shims, specs, torque, torquing |
