Em1 code p0133 help
Old 11-01-2011, 03:35 PM
TylerVE's Avatar
Default Em1 code p0133 help
Hey guys I'm new to the forum but have been lurking around for awhile. I recently purchased a 2000 Civic Si and after about a week of driving it the cel came on and the code was p0133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1) Both o2 sensors have recently been replaced, and I think it would be a wasted of money to go and buy another new one without seeing if its another problem. I was wondering what I should Troubleshoot, I have searched the forum and googled it and really am still in need of help. Any help would be greatly appreciated! Thanks!
Old 11-01-2011, 03:46 PM
Humphrizzle's Avatar
Default Re: Em1 Help
google search:
http://www.obd-codes.com/p0133
Old 11-01-2011, 03:55 PM
TylerVE's Avatar
Yeah I already looked at that but I wanted some advice from some honda guys about some steps to go about to see what the other causes could be like something in the wiring
92lxsleeper's Avatar
you should have your question in the title so people who actually do know will come in. just a "please help" will tend to turn people away. just a thought.
Old 11-01-2011, 03:57 PM
TylerVE's Avatar
Thanks for the advice will change
Old 11-01-2011, 04:25 PM
Default Re: Em1 code p0133 help
exhaust leak.
Old 11-01-2011, 04:36 PM
TylerVE's Avatar
Yeah I saw that it could be an exhaust leak when I googled it, I was wondering what other kind of things i could troubleshoot
Old 11-01-2011, 04:39 PM
Former User's Avatar
If there's no exhaust leak, replacing the primary O2 sensor should fix the problem.
Old 11-01-2011, 04:42 PM
TylerVE's Avatar
The sensor has just been replaced with in the last 2000 miles, Thats why it is weird that it is going off, Is there anyway to check the wiring between the o2 and the ecu? Thanks for the help so far everyone
Old 11-01-2011, 04:54 PM
Old 11-01-2011, 05:06 PM
TylerVE's Avatar
I saw when scanning through the manual earlier today, although I don't have the tools to do this, Thanks for everyone's help tho
Old 11-01-2011, 05:09 PM
You can inspect connector C123/C145 and resistance of the O2 wires that run through it.
You can also check for an exhaust leak.
Old 11-03-2011, 09:17 AM
92civlude's Avatar
Some brands of fuel and/or fuel additive packages may create deposits at the fuel injector tips. This build-up may cause slight air/fuel deviations between each cylinder. Build-up of deposits, when coupled with very specific driving conditions, may cause the MIL to come on and the PCM to store DTC P0133.
Old 11-03-2011, 10:44 AM
motegicivic's Avatar
check the wiring to the sensor, check the molex connector itself.
By the way what brand did you use?
and you are sure you have the right part number?
Also, did you reset the computer, did it come back?
does the car have the stock engine?
Old 06-13-2012, 11:40 PM
billsee1982's Avatar
Wondering if you found the problem or if you were still having the problem?
Old 06-19-2012, 10:31 AM
TVE
TVE's Avatar
It still pops on every now and then I usually turn it off and it stays off for a month or two, I also just brought my car to emissions in IL and passed,
Old 06-25-2012, 08:10 AM
so it comes on randomly?
Old 09-09-2012, 06:49 AM
TVE
TVE's Avatar
Now that code doesn't come back on anymore and the p0135 comes on so I went out and bought and o2 sensor from autozone reset the code and the cel comes on almost right after I reset the code with the obd2 scanner and the live data says its running so rich that it pegged the volts at the meter at 1.275 I'm really not sure what to check
Old 09-09-2012, 07:10 AM
syrtuning's Avatar
what i would do if i were u.. ill convert my obd2 to obd1 get a chipped p28 and a wide band and a dyno tune if its possible concedering that buying to oem o2 sensors its not cheap
Old 09-09-2012, 07:30 AM
Check whether 7.5A fuse 15 is blown and whether voltage from fuse 15 reaches the O2 sensor plug.
Old 09-09-2012, 07:38 PM
TVE
TVE's Avatar
Thanks guys will try those things, reguardless of that today I took it to the local strip with some friends and ran a 15 flat in it, I was shocked, stock b16 i/h/e with mounts and p/s delete wasnt expecting that at all hopefully going to get an ecu soon to see what it'll do with a good tune and 2 step. Thanks for all your help
juan23_adolfo
08-28-2017 07:41 PM
ezejdm
09-27-2013 06:36 AM
Wilka
03-20-2013 10:11 PM
RVCA97
12-28-2005 09:24 AM
alexb16hb
04-17-2004 10:54 PM
Quick Reply: Em1 code p0133 help
