Turn Signals not working
Old 10-25-2011, 05:02 PM
Ek Steve's Avatar
Default Turn Signals not working
My turn signals work one min. then don't work the next. They started messing up after I hit the hazard lights button. It chooses when to work.
Old 10-25-2011, 05:32 PM
sde780's Avatar
Default Re: Turn Signals not working
Check fuses, make sure one of the bulbs isn't burnt/starting to fail
Old 10-25-2011, 06:10 PM
Slacker93eg's Avatar
Mines doing the same thing, all the sockets wiring is screwed up.
Old 10-25-2011, 06:22 PM
Ek Steve's Avatar
Do the turn signal lights blink on the dash when the blinkers aren't working? Mine doesn't show up at all and it makes a noise like they are on, but they aren't.
Old 10-25-2011, 07:01 PM
vinem1's Avatar
The same thing happened to me when i replace my radio unit , i forgot to plug back the hazard lights button, if all your fuses and wires are correct take a look at it. or maybe is just a fuse .
Old 10-25-2011, 07:24 PM
EJ2B16's Avatar
same problem with my civic!!!!
i have to turn my blinkers 10sec before i want to turn and all of a sudden they work. dont know what it is. any help?. its not the fuses its not the bulbs....
http://thehid-spot.webs.com/
Old 10-25-2011, 08:44 PM
sde780's Avatar
So the relay clicks but there's no light? Did you check the bulbs?
Old 10-25-2011, 08:52 PM
Ek Steve's Avatar
yes and when it is working the turn signals show up on my dash so it cant be the bulbs
Old 10-25-2011, 09:25 PM
Former User's Avatar
Pry the hazard lights switch out of the dash and check whether the connector is not fully seated on the switch.
Old 10-26-2011, 03:48 PM
Ek Steve's Avatar
it was the hazards, its fixed now thanks guys. oh and does anyone know why my blinker switch doesn't click off when i turn( i have a momo steering wheel if that helps). Thanks!
Old 10-28-2011, 07:02 PM
vinem1's Avatar
You probably need to replace the blinker switch or try to clean it and check the cables.
Old 01-14-2020, 03:09 PM
Butler123's Avatar
My blinkers are not working, I turn blinker on and doesn’t even flash on dash or nothing. What could this be
Old 01-14-2020, 03:59 PM
muellersfan's Avatar
Check the fuse. Do the hazard lights work?
Old 01-14-2020, 07:10 PM
Malt-liquor's Avatar
Check Fuse first, then replace bulb, Check if there's any rust inside the socket.
your local ricer
05-06-2010 04:09 PM
jjtreff
08-08-2008 10:06 PM
efyou
09-13-2006 07:09 AM
premo_si
08-05-2006 10:07 AM
100bhp
08-09-2003 08:24 PM
Quick Reply: Turn Signals not working
