How do you force pass. window up '93 accord
Old 10-22-2011, 01:43 PM
lastronaut's Avatar
Default How do you force pass. window up '93 accord
My passenger window wont go all the way up, the motor is bad. its down about 1/4-1/2 an inch and rain is getting in. whats the easiest way to force that window up, or what to seal with. thanks
Old 10-22-2011, 02:00 PM
rayo53's Avatar
Default Re: How do you force pass. window up '93 accord
Just put both your palms on the window and have someone push the "up" switch on the door and push it up. Or just push it up, push the button and work your way up. Most Accords do that.
Old 10-22-2011, 02:12 PM
lastronaut's Avatar
I just tried that, the window button doesnt do anything when pushed. im putting all my strength into it and trying to get the window up and it wont. im trying to avoid turning this into a huge project. thanks for your input
Old 10-22-2011, 02:28 PM
Smallboxx's Avatar
take the door panel off and remove window regulator motor (it has three bolts holding it into the door panel) and then unbolt the regulator (it is the bracket assembly that the motor drives) from the window and ... there u go. slide the window up and figure out how to make it stay up (any way u can)
Old 10-24-2011, 03:06 AM
hondamark35's Avatar
I've wedged PVC pipe, pieces of wood... whatever i had laying around that was the right hieght inside the door to hold the window shut for a few days while waiting for parts to ship. Used some loops of duct tape or zip ties to secure it and keep it from slipping out while going down the road.
inaety
06-07-2010 11:53 PM
acc0rdf22
10-08-2009 12:17 PM
EKidd
05-30-2007 05:44 PM
JDM custums
11-16-2006 04:24 PM
Knightmare69
04-24-2006 09:24 AM
Quick Reply: How do you force pass. window up '93 accord
