Valve Cover Gasket replacement HELP!
Old 08-16-2011, 08:09 AM
NayborhoodJohnny's Avatar
Default Valve Cover Gasket replacement HELP!
I need to change my gasket on my valve cover.
There is oil leaking out of the valve cover and also into the spark plugs.
I was thinking of buying ebay oem set and doing it myself.
I think i tried it before and the valve cover itself was really hard to pull off.
Any advice or suggestions?
Old 08-16-2011, 08:13 AM
Wrona's Avatar
Default Re: Valve Cover Gasket replacement HELP!
Valvecover is like the easiest to fix i dont know how ur having problems with it...
remove all bolts that hold the calvecover between the valvecover and the head wedge a very thing screw driver and try to pry it up...
i just get the Autozone gasket for my cars when they need it comes with the sparkplug gaskets and the valvecover itself
Old 08-16-2011, 08:16 AM
mhax's Avatar
Just did it the other on my integra and it was easy. Just be sur to remove the rubber thing that is under all 8 bolts, if not you will have a hard time trying to remove the valve cover.
Old 08-16-2011, 08:20 AM
GagnarTheUnruly's Avatar
Valve cover is super easy to pull. Just remove the spark plug holders and the several nuts that hold the VC on. Make sure you honda-bond the square corners when you install the new gasket. I get my gaskets from OEM suppliers, they may ship a little packet of Honda-bond with the gasket -- can't remember.
Old 08-16-2011, 09:01 AM
TheHolidayCrew's Avatar
Cake to get off! Did you miss a nut maybe??
Old 08-16-2011, 06:03 PM
fcm
Old Fart
fcm's Avatar
I would stay away from eBay stuff and just get a set from an OEM supplier... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal 95
Old 08-16-2011, 06:37 PM
YodajdmEK4's Avatar
Valve cover gasket should be easy to replace.
Old 08-16-2011, 07:26 PM
circlejerk911's Avatar
it could be sealed on with something stupid, or maybe you missed a nut..?
and get OEM from honda, its like 45-55 bucks and it comes with everything you need, gasket and all the plastic type washers for the plugs and bolts.
Old 08-16-2011, 07:54 PM
Wrona's Avatar
if my gf can replace a valve cover gasket and shes new to cars u can replace a valvecover gasket its just that u didnt try
Old 08-16-2011, 08:43 PM
wunfstgsr's Avatar
wish my girl could change the vc gasket she can barely pump gas in it!
sometimes the honda bond holds it down a bit, try a small pry bar on each corner and wiggle it till it comes loose!
Old 08-16-2011, 09:45 PM
el crapitan's Avatar
Just tap the corner of the vc with a rubber mallet. Safer than prying
Old 08-16-2011, 09:56 PM
Bloody Arro's Avatar
You know.... There's no need to be douchebags about it.
woooo "it's easy, my girlfriend can do it" - douche.
If you have all of the nuts off and are still having problems getting off the valve cover, try using a flat head screwdriver.
Old 08-16-2011, 10:10 PM
Wrona is the only person who gave OP crap about it, and he was only kidding. Besides, it is kind of funny because VCs are normally so easy to remove...
OP if you need to remove it with prying/tapping, be VERY careful about using any implements with metal edges. The VC is soft aluminum that damages easily and you don't want anything interfering with the seal. Not that the outer edge is really where the seal happens but you can't be too careful.
Old 08-16-2011, 10:21 PM
subgeniusdude's Avatar
Yep,easy job,just use Hondabond around the curved part that goes over the cam,or some other sealant.I've used the FelPro gasket set from Autozone before,it was good quality and came with everything (vc gasket,spark plug tube seals,and grommets).
Old 08-19-2011, 09:39 PM
Dannyx321's Avatar
Easy job man. if I can do it, surely you can
Old 08-19-2011, 10:14 PM
Hidenplanvew's Avatar
Replace the cam seal too while your there
Old 08-19-2011, 10:22 PM
Don't give him any ideas
Old 08-19-2011, 10:23 PM
Now would also be a good time to do a valve adjustment!
curtie94
04-02-2011 03:46 PM
90laser_rst
09-26-2006 07:15 AM
knucklehead11
07-31-2004 05:13 AM
The_In_Kid
09-12-2002 06:12 PM
NONKonformyst
05-10-2002 06:11 PM
Quick Reply: Valve Cover Gasket replacement HELP!
