Cassette player connection
Old 08-12-2011, 08:20 AM
broody's Avatar
Default Cassette player connection
Hi, I got a cassette player like this one and I want to know if I can install it in my 1999 civic with am/fm radio
http://3.bp.blogspot.com/_Yey01SeCLU.../s1600/014.JPG
The cassette player has a round grey connector, while my radio only has squared connectors in the back, is it possible to connect it with an adapter or something? I'm not sure if it's from a civic, crv or something else.
Thanks.
Old 08-12-2011, 11:50 AM
jdmadam's Avatar
Default Re: Cassette player connection
are there wires coming off the cassette player to this gray connectory? or is it just a connector on back of the radio with no wires?
Old 08-12-2011, 12:50 PM
broody's Avatar
These is a wire coming out of the cassette player, it also has a female plug, the same type as the wire end.
Old 08-12-2011, 02:05 PM
motegicivic's Avatar
Thanks.
That deck might be for the 96 to 98 models only, I think the 99 and 00 used a different plug so it is not compatible. esp if yours has the square plug.
My 96 has a round plug.
When you got the deck I assume it was used, did it come off a car or was it by itself, did the seller tell you what car it was off of?
Old 08-12-2011, 02:13 PM
broody's Avatar
It was at the scrapyard in a civic, a 96-98 I guess. Is there an adapter? Does the cassette player has a resale value (like 10-15$)?
Old 08-12-2011, 02:24 PM
I am guessing no adapter.
Only way is to get a used cassette harness (wire with square plug on both ends) for your 99 deck and cut it, then get a used harness for a 96 and cut it.
Hopefully same amount of wires and possible colors match it up.........this is a gamble.
You might be better off searching out a used 99 deck, and make sure you get the wire to hook it up.
Do you really want a cassette deck that bad?
If you really want a cassette deck, click here and scroll down but it is $134.
http://www.handa-accessories.com/civelec00.html
Old 08-12-2011, 03:06 PM
broody's Avatar
It was to plug my mp3, but I'll try to find a fm tuner for my mp3 then, but these thing aren't cheap at the store, I don't know on ebay.
Old 08-12-2011, 03:24 PM
Wait you wanted a deck so you can run a cassette adapter for your mp3?
Here is a link for a direct input to the back of yur radio.
http://www.clubcivic.com/board/showthread.php?t=69893
There is a part number for the Pie adapter.
Old 08-12-2011, 04:19 PM
broody's Avatar
That may be a nice option, but it's around 50$ on the internet, not 20$.
Old 08-13-2011, 06:57 AM
Yes, i noticed that.
I would google various aux adapters for you car and see if there some cheaper ones.
They will sound much better than a cassette adapter though.
Old 08-14-2011, 07:46 AM
jdmadam's Avatar
You can make the cassette player work. All you have to do is buy a install harness which is like $10 bucks for your car at any store like walmart,bestbuy, target etc. so you dont have to cut your car's harness. Cut the connector off the cassette player and cut a splice the wires together. Its pretty easy to cut the and splice the wires together. If you dont know how to do it than any one who has installed a cd player or any other deck could do it for you.
Old 08-14-2011, 09:34 AM
These decks are different, they have a round or square plug made to into the back of the factory radio.
Old 08-15-2011, 03:56 PM
jdmadam's Avatar
misread his post. I thought it said that it had wires coming off back of the cassette player.
checko
09-29-2011 03:33 PM
BlueIntegraBoy
03-24-2007 12:27 PM
draperj09
Audio / Security / Video
13
11-19-2006 01:32 PM
integlude
11-14-2004 07:13 PM
Junior Carioca
02-28-2004 05:14 AM
Quick Reply: Cassette player connection
