CLICK HERE all of you curious about suspension setups and their costs/reliability.
Old 01-08-2012, 03:15 PM
  #251
Machetero809's Avatar
Default Re: CLICK HERE all of you curious about suspension setups and their costs/reliability
@Libertariat
Thank you, i will then proceed to order the koni, now i might be asking too much but theres no way i can find the coilover kit for my 2000 honda accord EX coupe 4cyl. i been browsing around but nothing. any good direct link that i can checkout ? thanks thanks thanks ....
Old 01-08-2012, 04:39 PM
  #252
The Grumpiest
grumblemarc's Avatar
Originally Posted by Machetero809
@Libertariat
He said Koni for the shocks and the Koni specific Ground Control coilovers. Pick your spring rates or get the OTS ones.
Old 01-08-2012, 07:15 PM
  #253
CivicBoner's Avatar
what if i would want my car " dumped "...
meaning probably alot lower than you are running at the moment with your progress cs - II
, which coils would you prefer?... i have a 99 civic dx, im looking to get the 16" rims, with low profile tires... and make it maybe 5- fingers off the ground, to point where i must avoid almost all speed bumps... would cs - II still be a good choice?
Old 01-08-2012, 08:25 PM
  #254
xDelSolx93's Avatar
Cs-IIs are more of a competition use coilover. For autocross.
Old 01-09-2012, 06:23 AM
  #255
The Grumpiest
Uh, no. You can use them for Autocross, I guess like anything else, but this not meant strictly competition use. Go to the Progress website and read up. As a matter of fact ALL of you having difficulty making a choice should go to the manufacturers website and read up. If you have questions after that then call up and speak to a rep. Whatever the choice you make.
I think we've given you enough information to put you in the right direction but ultimately the decision is yours and the money if definitely yours. Spring rates, as they relate to comfort and ride quality are totally subjective.
Old 01-09-2012, 06:25 AM
  #256
The Grumpiest
@grumblemarc. I wish i could understand this more, is my first time messing with my suspension. i was doing some research and im almost there but a bit lost on the spring rates ?? would that be how lower i want the car maybe ?? I WISH SOMEONE PUT ON TOGETHER THE SETUP FOR MY 2000 HONDA ACCORD EX COUPE 4CYL. I REALLY DONT WANT TO ORDER THE WRONG SETUP PARTS... CAN SOMEONE DO THIS FOR ME AND ILL POST THE BEFORE AND AFTER PICTURE BY NEXT WEEK WHEN I RECEIVE THE PARTS. !!!!!! MILLION THANKS ! I HAVE LEARNED ALOT WITH U GUYS..DEFINATELY WILL RECOMMEND TO MY FRIENDS.
Find a retailer and call them up.
Old 01-09-2012, 06:28 AM
  #257
xDelSolx93's Avatar
They're most definitely not for "slamming" your car.
Old 01-09-2012, 06:30 AM
  #258
The Grumpiest
You probably could but that's not what they are recommended for. Some guy posted this exact same thing. Bought them because he didn't do his research and thought that since they were good he could slam his car but didn't understand squat about spring rates. But with the soft springs rates that was not the case and he was not happy.
Old 01-09-2012, 10:27 AM
  #259
@Libertariat ....Thanks !!!
Old 01-10-2012, 09:19 AM
  #260
STOCK_SOHC_DX's Avatar
Originally Posted by Design
KW has been around since the 90's and has one of the broadest application ranges for coilovers. Very good track record despite the high volume. I like AMR but they are a young company and tend to be a bit secretive over their dynos (nothing against Andy of course).
This KW dyno was done by an S2K owner. Take it for what it's worth:
KW is a quality product, but can you tell me who makes their shocks?
Old 01-17-2012, 11:08 AM
  #261
Dannyxafi's Avatar
You dont know any good ones for a 90 honda civic sedan?
Old 01-29-2012, 09:32 PM
  #262
Skeero's Avatar
What spring rates are TOO stiff for the road? I want to take the car to the drag strip, and want stiffer suspension but if I go around a corner at a decent speed I don't want the *** end to step out on me or bounce off the ground. Or whatever crazy **** would happen. I'm not worried about the stiff feeling driving, or noise or anything. Just worried about if I hit a pot hole and start losing control, or doing the same in a hard turn.
Any advice? I'm sure 18kg and 12kg wouldn't be fun on the street. 12kF and 10KR?
I think I'm going to go with the GC/K set up but I'm not sure what spring rates to get :/
Thanks.
Old 01-30-2012, 11:25 AM
  #263
Design's Avatar
Everything is done in house at their Fichtenberg facility.
Old 01-30-2012, 11:43 AM
  #264
SHG_Claudio's Avatar
Thanks.
Spring rates are relative to the motion ratios of each independent model. What car do you have? 18kg and 12kg is very stiff on most cars. My friend has an EP3 and his front springs are 18kg and it feels alright, its not uncomfortable. The car is not bouncy or anything, it depends more on the shocks. On an EG however for example it would be very very stiff.
You can call Ground Control and they will help you pick rates based on your needs. Just remember that if you go with stiff rates that you make sure your bushings and other suspension components are in good order
Old 01-30-2012, 01:19 PM
  #265
Skeero's Avatar
2000 Civic Si. I plan on upgrading all the bushings when I decide on which kit I want to go with.
I'm not worried about ride "quality" I'm worried about the *** end bouncing a wheel from not dodging a pothole and losing control or some crazy ****. Vibration and all that I'm not worried about in the least.
Old 01-30-2012, 02:05 PM
  #266
That wouldn't be likely to happen unless you had a really stiff swaybar in the rear or stiffer rear springs than the front. Its really up to what you want to do to the car. Track only? Street and occasional track? Etc. I'm on 10k/6k and its a stiff setup that can handle well and is streetable. Sounds to me you would be looking for something in the 12/14k front and 8/10k rear range. Call up GC, they will help!
Old 01-30-2012, 02:27 PM
  #267
ROOKind's Avatar
higher quality product the first time is a lot better than trying to cut corners to do more to your car sooner.
Agreeeeeeeed!
Old 01-30-2012, 03:11 PM
  #268
Skeero's Avatar
I'll be looking for something to add traction to a sleeved lsv 6262. lol. Breaking it in now, and trying to figure out what all I can do to aid traction on the street and strip. Slicks I know on track, and DR's on street. But other than those.
Old 01-31-2012, 07:00 AM
  #269
Ek Forever y0!
Libertariat's Avatar
Added a new <$600 category.
Old 01-31-2012, 09:02 AM
  #270
resko1's Avatar
So libertariat, your saying gr2's are decent? Problem i have is i have a da integra and there isnt many options for less expensive shocks. So far all i found was gr2's, tokico hp's, or skunk 2. Im using h&r sport springs so 1.8" drop. What would be your suggestion?
Old 01-31-2012, 09:16 AM
  #271
The Grumpiest
The whole first post is his recommendation. Check the new sub $600 section he added.
Old 01-31-2012, 09:19 AM
  #272
maxx13ccs's Avatar
Veryy good posting sticky
Old 01-31-2012, 10:02 AM
  #273
Ek Forever y0!
I'm saying they are probably better than nothing. They are OE replacement shocks and have a better reputation than tokico HPs. With the sport springs I would get Koni yellows or Tokico illuminas.
Old 01-31-2012, 11:03 AM
  #274
resko1's Avatar
thanks. I was actually looking at the illumina's as a step up choice. Heard the s2's were quite bouncy even though they claim their built for lowering springs. So that left me with gr2's or tokico hp's. Thanks for the info!
Old 01-31-2012, 06:57 PM
  #275
N/A*GSR's Avatar
Tunersports.com has the Koni Str.t shocks on sale. I know for my DC2 the price with the NewYearSavings code was $280 shipped, that's the lowest I've found them anywhere. Way better choice than Tokico Blues for a DD.
Quick Reply: CLICK HERE all of you curious about suspension setups and their costs/reliability.
