> Tech/Misc
Old 07-23-2011, 02:36 PM   #1
fcm
Old Fart
fcm's Avatar
Default Simple DIY start circuit test, [bypass jump]
You will need a 12V test light and a jumper lead.
Unplug the starter lead from the starter solenoid terminal, looks like this, black terminal...
Starter lead terminal, looks like this...
Pull back the insulation from terminal...
Plug it back in and clamp jumper to it...
Make sure car is not in gear and set hand brake, touch other end of jumper to batt. pos.(+) post...
If engine cranks, starter and starter solenoid are good.
Clamp test light ground to the starter lead terminal, [just like the jumper lead was]...
Stick the test light probe into the batt. neg.(-) post...
If you are alone, you can see the test light through the bottom of hood...
Turn ign. switch to start, if test light turns on, start circuit, [ign. switch, CIS, starter relay (A/T gear position switch) and wiring is good.
The test light "test" is good if engine cranking is intermittent, if test light turns on without engine crank, the problem is the starter, starter solenoid or power or ground for the starter, if the test light does not light up, the problem is the ign. switch, CIS, starter relay, [A/T gear position switch] or wiring for the above and more testing is needed.
More to come if needed. 94
You get what you pay for.
Nothing is impossible, the impossible takes longer and costs more money.
fcm is offline   Reply With Quote
Old 07-23-2011, 02:41 PM   #2
Drive 4 fun
Default Re: Simple DIY start circuit test, [bypass jump]
Nice write up!
Drive 4 fun is offline   Reply With Quote
Old 07-24-2011, 11:26 AM   #3
el crapitan
Hey great thread. This should obliterate at least half of the "my car won't crank" threads that were to come.
Hopefully this gets stickied
the richest ones are not those who have the most, but those who need the least
-bernhausen specialty automotive- BC's diesel truck headquarters
el crapitan is offline   Reply With Quote
Old 07-24-2011, 02:49 PM   #4
BryanM.
Resident Gearhead
BryanM.'s Avatar
iTrader Rating: (1)
This is a handy write-up.
BryanM. is offline   Reply With Quote
Old 08-07-2011, 08:03 PM   #5
98bucket
98bucket's Avatar
awesome.
Not tonight Ladies! I'm just here to drink!
Originally Posted by SIRIUS View Post
Bunch of ****** on here?
tumblr.
98bucket is offline   Reply With Quote
Old 08-07-2011, 10:19 PM   #6
civickiller
1996 Honda Civic
civickiller's Avatar
Send a message via AIM to civickiller
thanks fcm, should be stickied
Originally Posted by Turbo-LS View Post
Boost is like crack cocaine of the automotive world.
Diagnosed w/MS June '06
civickiller is offline   Reply With Quote
Old 08-23-2011, 11:20 AM   #7
fcm
Old Fart
fcm's Avatar
I wish it was, I have to keep looking for it when I want to link it. 94
Old 09-10-2011, 08:43 PM   #8
mike:
1994 Honda Civic
Nice write-up but if I can add from experience, jumping the starter doesn't always rule out the starter/starter solenoid. I had problems with a couple re-man starters from advance where the solenoid would stick even after jumping, as in the starter would click but wouldn't turn over. The one I have now (3rd times the charm) starts up every time
mike: is offline   Reply With Quote
Old 09-29-2011, 05:33 PM   #9
fcm
Old Fart
fcm's Avatar
If it does not work when doing a bypass jump, [jumping] then it is the starter or starter solenoid, that's the point of the bypass jump, to bypass all the things before the solenoid that might be the problem. 94
Old 11-20-2011, 02:48 PM   #10
kzar
You thought you were done with this post.
Ok, I have a '95 Civic with an A/T transmission. Have trouble getting the starter to crank. Checked all the paths from the ignition circuit and all is good. If I put a jumper wire on the positive battery terminal to the starter solenoid it doesn't immediately start. After a few minutes it starts cranking away. I've brought the starter in and it tests good. Also, I have a brand new battery and cable from the battery to the starter. Could my starter have a bad ground to the block? Hard to believe. Thoughts?
kzar is offline   Reply With Quote
Old 11-20-2011, 04:38 PM   #11
mechanix619
mechanix619's Avatar
The transmission ground could be bad or the starter solenoid and contact point.
mechanix619 is offline   Reply With Quote
Old 01-20-2012, 12:23 PM   #12
turbohatch96y7
turbohatch96y7's Avatar
iTrader Rating: (8)
The starter is an electric motor it can test good but the solenoid could be your problem.
Always use a voltmeter rather than a test light. If your solenoid coil isn't getting 12v its not going to create enough electromotive force to close the contact tips ( transfers power over to your starter). Or your tips can close but be pitted and not have a good connection. If the tips don't close the starter won't get 12v. Or battery voltage. Also make sure the starter is grounded it typicly grounds threw the starter case.
Originally Posted by GoodEyeSniper View Post
I love fat bitches that's my ****** problem?
turbohatch96y7 is offline   Reply With Quote
Old 01-20-2012, 12:24 PM   #13
turbohatch96y7
iTrader Rating: (8)
And instead of a jumper to your battery you could use an insulated screw driver and jump your solenoid to the starter power cable.
Old 01-23-2012, 02:02 PM   #14
kzar
Problem solved. The bottom line the problem was a 1 year old rebuilt starter and / or solenoid from Pep Boys. The hard part was I brought the starter into a auto parts store and they tested it and declared it was good! I then checked to make sure I had a good ground path from the starter to the block to the battery ground cable, all good. I was stumped. I had already replaced the postive battery cable and clamp to the battery so I knew the whole cable was good. Things just didn't add up. I pulled the starter again and brought it to Pep Boys where I originally bought the starter. Pep Boys declared the starter dead on arrival and promptly gave me a brand new starter for FREE. All is well now. thanks for the help.
Old 01-23-2012, 02:36 PM   #15
turbohatch96y7
iTrader Rating: (8)
yeah never take electrcal stuff to pep boys autozone etc. When I was 16 I took them myalternator and said it was good ended up being bad and had my car down for a week cause of the morons.
They have the equipment to test it but not the brains to test it right..
They can sell parts like a **** though
Old 01-23-2012, 04:50 PM   #16
fcm
Old Fart
fcm's Avatar
The problem with pulling a starter or alt. to have it tested at a car parts store is the starter or alt. is not tested under load, and although a lot of starters and alt. will test as "good" when not under load, when loaded down it is a completely diff. story. 94
Old 11-30-2012, 11:17 AM   #17
fcm
Old Fart
fcm's Avatar
Bump to the top to make it easier to find. 94
Old 12-20-2012, 07:34 PM   #18
1991integrada9
Send a message via AIM to 1991integrada9
Bump
1991integrada9 is offline   Reply With Quote
Old 02-07-2013, 12:07 AM   #19
559geeser
1998 Acura Integra
I think I am going to have to get a Voltmeter and jumper lead to check this out. My 98 gsr won't turn over. Maybe 1-1000 cranks it will, I have changed all wires to starter checked fuses changed the starter 3 times. Funny thing is that last time my car turned over I guess my buddy saw some sparks from the starter. If I try to jump the car it turns right on...I really want to take care of this problem. I am new to the H-T team so here we go!
559geeser is offline   Reply With Quote
02, 2004, 91, accord, acura, diy, fix, gear, honda, jump, light, position, sensor, solenoid, starter, switch, test
