Honda accord 1993 automatic transmission shift issues
Old 09-16-2013, 03:41 AM
  #26
Hammer90's Avatar
Default Re: Honda accord 1993 automatic transmission shift issues
Mad Mike - Nope never found it - was up there looking a number of times. Had everything pulled out (needed to do that anyway to replace the TCU). May do it one more time - but since the car is running good not essential now.
For HondaGirl1991- no idea if your problem is the TCU. If it is grinding would think it is something mechanical
Old 09-18-2013, 04:35 PM
  #27
MM Gruppe B
MAD_MIKE's Avatar
Originally Posted by honda.girl.1991
I just hear a grinding noise when driving. I know what is going on I have a 199656 miles in my 1991 Honda Accord. Is it te TCU?
First check your transmission fluid level. Turn the car on, place it in every gear for 5 seconds. Then check the fluid level. Pull the dipstick, wipe it off, reinsert, and pull it again. It should be with-in the hatch marks.
Old 05-19-2014, 08:43 AM
  #28
devin2k9's Avatar
Hey guys usually I come across these thread s and find my answer but I'm having the same issue with my 1993 honda accord se. Drained the transmission, it shifts a lot better now, but at 70mph it's revving at almost 3200-3300 rpm. I've only had toyota and none of which has given me any types of problems like this so I'm pretty much blind. It is an automatic with D4. The p and D4 light do not come on at the same time but after about 5 minutes of driving over 60mph the check engine light does visit every so often.
Old 05-19-2014, 08:45 AM
  #29
devin2k9's Avatar
Hey guys usually I come across these thread s and find my answer but I'm having the same issue with my 1993 honda accord se. Drained the transmission, it shifts a lot better now, but at 70mph it's revving at almost 3200-3300 rpm. I've only had toyota and none of which has given me any types of problems like this so I'm pretty much blind. It is an automatic with D4. The p and D4 light do not come on at the same time but after about 5 minutes of driving over 60mph the check engine light does visit every so often. Irrelevant but I should add, my 1992 toyota celica 1.6 is at 3,000 rpm at 70mph, with 300, xxx miles, 95 camry at 2 500 rpm at 70
Old 04-29-2015, 09:04 AM
  #30
jlpxx's Avatar
Justin are you still repairing the TCU units? If yes how do I get mine to you for service?
Old 04-16-2016, 12:47 PM
  #31
Jamie Gray's Avatar
I have a similar problem, 92 honda accord, stated serging in idle so I cleaned the iacv, was temp fix for a week so I replaces it with new one, now the car will drive fine until down shifting from 2nd the first then serging in park. Have cleaned the fitv any sugestions?
Old 04-17-2016, 11:15 AM
  #32
MM Gruppe B
MAD_MIKE's Avatar
Check for vacuum leaks.
Check for coolant leaks around the FITV.
Verify the coolant system is properly bled. Get a two foot piece of clear nylon hose, attach it to the bleed screw on the thermostat housing(when cold) and crack open the bleeder. There should be bubble free coolant.
Old 04-17-2016, 11:24 AM
  #33
Jamie Gray's Avatar
Thank you I flushed the radiator but I will give that a try.
Old 04-18-2016, 07:26 AM
  #34
Senorsquez23's Avatar
Originally Posted by justinsbg
He's talking about the Transmission Control Unit, which is the computer that controls the transmission operation. It's a very common problem on 1990-1993 Accords. If you open up the unit you want to look for any burnt spots on the PC board around the capacitors(it's located behind the passenger's floor board and it's the bronz colored computer). It's usually one corner of the TCU that fails. It can be repaired, by me if you choose for about $80.00. I use better quality components to repair the TCU than what's installed. Check your codes as well. If you have shift solenoid codes you'll want to test them. Sometimes they fail which then causes the TCU to fail. If you don't fix the solenoids, the problem with the TCU will return. If you need any help diagnosing the solenoids I can help you with that.
Are these problems common in 94's as well? My cel shows the 9 code which is the cylinder positioning sensor (inside the dist). I replaced the dist and it the light is still on. The transmission sometimes goes through all the gears but sometimes I'll get to 60-70mph and it will run about 2500rpms. After a while it will shift and lower back to around 2000. Is this along the same lines as the OP?
Old 04-18-2016, 10:46 AM
  #35
Jamie Gray's Avatar
I did the brake bleeder screw test, good, will it help to know it gets worse when running the ac? Also could egr clogged be causing this?
Old 04-19-2016, 07:32 AM
  #36
Jamie Gray's Avatar
Turns out there was a hole in my fi tv and I did not properly burp the radiator of a combination of the two fixed my issue thank you for your advice
dcsalling
10-20-2021 11:00 AM
skitt123
03-22-2015 02:50 AM
00Accord03Odyssey
01-22-2009 06:30 PM
rocko617
05-12-2003 06:54 PM
Quick Reply: Honda accord 1993 automatic transmission shift issues
