'06 Honda Civic HVAC Cabin Air Filter Replacement
Old 07-01-2011, 07:46 AM
techtalk's Avatar
Default '06 Honda Civic HVAC Cabin Air Filter Replacement
Hello Honda-heads!
Happy Friday everyone! The summertime has arrived so I decided to tackle replacing the HVAC system cabin air filter in my '06 Civic. The job is pretty straight-forward and doesn't require any tools so if anyone else is interested in performing this job themselves then don't be daunted! I wrote this handy-dandy write-up on the procedure for my '06 model but it applies to model years '06-'11.
Some of the suitable replacement A/C cabin air filters for the Honda Civic include the Purolator C35519, Wix 24815, AC Delco CF159, and Beck Arnley 042-2023. Personally, I'm a bit of a cheapskate (I prefer the term fiscally conservative ) so I bought a $15 OEM filter from www.hondapartsnow.com: http://www.hondapartsnow.com/Page_Pr...Cooling%20Unit. The part number is 80292-SDA-A01 on this site as well as from the dealer.
Anywhoo, without further ado here's how one would go about replacing the A/C filter for their '06-'11 Civic:
1) The first step is to get into the front passenger seat of the car and open up the glove box.
2) Then pull inwards on both side walls of the glove box to release the rubber stops on each side of the glove box. When the rubber stops are clear, you can lower the glove box to the passenger floorboard. Behind the glove box, you'll see the blower motor housing and the rectangular black plastic cabin air filter cover.
3) To remove the cabin air filter element and tray, push in on the two side tabs that secure it to the blower motor housing. Then slide the tray straight out. To separate the filter element from the black plastic tray, pull or push the element upwards out of the tray.
4) When replacing the cabin air filter, be sure to take note of the "Air Flow" markings on the element. With the new or cleaned cabin air filter back in the black plastic tray, slide it back into the slot in the blower motor housing until the two side tabs "click" into place.
5) Double check that the tray is securely in the blower motor housing before raising up the glove box. To re-attach the glove box, push inwards on both sides while simultaneously raising the rubber stops back into place. Close the glove box to complete the job.
6) Sit back, open up a cold one and enjoy the fruit of your mechanical prowess!
You may shop all the oem honda parts above at hondapartsnow.com
Old 07-01-2011, 09:14 PM
91_Civic_hybrid's Avatar
Default Re: '06 Honda Civic HVAC Cabin Air Filter Replacement
For a little extra scent to the car cut off the band to an air fresher and place it under the filter. You may want to attach it with some zip ties or something like that to keep it from falling down. I just placed mine in there and haven't had an issues. But better to be safe.
Old 07-02-2011, 09:32 AM
K5^
Brand New
K5^'s Avatar
Good write up.
Old 07-03-2011, 06:28 PM
Uncle_Ben's Avatar
Cool. I'll be trying this in the near future for sure... what's the recommended interval for replacement?
Old 07-03-2011, 06:35 PM
Lucious's Avatar
I was told 15,000 or everytime you need to change your engine filter.
Old 07-05-2011, 07:52 AM
hoangy's Avatar
I normally change mine about 10k-12k miles.
Old 07-07-2011, 03:13 PM
CL23's Avatar
nice thread, need to change mine soon
Old 08-24-2011, 03:58 PM
Uncle_Ben's Avatar
Wow this literally took two minutes, I couldn't believe how easy it was. I mean compared to changing out the headlights or the oil on the Si, this ranks easier by 1000%. Great instructions.
I couldn't tell at first if my filter was dirty it was supposed to have that greyish look to the fins, but then looking at it from an above angle you can see the dirt haha. I found a replacement from eBay for around $15, win.
Old 04-27-2012, 07:17 PM
techtalk's Avatar
Originally Posted by K5^
Good write up.
Thank you.
Old 04-30-2012, 07:38 PM
h22_civ's Avatar
great write up, thank you!
Old 05-01-2012, 06:17 AM
Bouncing_Soulz's Avatar
Excellent. I have been wondering how to do this. With all the pollen I am sure I am past due.
Good timing and good write up!
Thanks!
Old 05-01-2012, 12:24 PM
Turtle_FA5's Avatar
this will also stop allergies in the car?
NOFX
189
11-10-2019 02:57 PM
wcladman
05-24-2017 07:23 AM
vitaly871
05-11-2016 01:41 AM
Quick Reply: '06 Honda Civic HVAC Cabin Air Filter Replacement
