My B18C1 Engine Build/Assembly
Old 02-19-2012, 06:44 AM
  #1251
Moderator
TheShodan's Avatar
Default Re: My B18C1 Engine Build/Assembly
Originally Posted by Whiterice-gsr
as opposed to the aem kit at 1000 bucks. the only thing i have reserves about is the msd cap and rotor ive had one shatter on me before and ive never had an oem one shatter. this was before i was turboed too.
Interesting. Never had a "shattered" MSD coil in 10 years. I wonder how it would do something like that. Curious.
Old 02-19-2012, 07:28 AM
  #1252
Whiterice-gsr's Avatar
not the coil just the cap and rotor, or mainly the rotor blew apart inside the cap, i havent the foggyest what happened but i replaced the cap and rotor with oem then i had stalling issues when it warmed up so i said screw it and bought a whole new dizzy. never really thought about it too much.
Old 02-19-2012, 07:38 AM
  #1253
did a quick search for msd related threads, heres what i found.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/stupid-msd-94-gsr-distributor-cap-vs-94-integra-2889720/
http://www.clubintegra.com/board/showthread.php?t=25386
Old 02-19-2012, 10:50 AM
  #1254
Moderator
TheShodan's Avatar
the first link I can see occurring , but not because of them "not being reliable where our cars live in the higher range). I think that tends to be more about the part number of the cap they used, as well as perhaps just a bad batch. (Not to defend MSD, but many things go wrong even in v8 world, it doesn't mean its because its on "our" cars
The second one sounds a bit more like the rotor screw just wasn't on well enough. I've had OEMs break up on my daily drivers because the gasket for the cap wasn't on, or i didn't use the right torque on a stripped screw to come out.
Some of it is MSDs fault, but there aren't many choices in caps to choose from, and I wouldn't let one or 2 spoil a batch of 10,000 units. Its interesting people will post on the bad stuff of everything to make it easier to find, but never GOOD reviews. If someone does, all of a sudden their accused of "dick riding", "brown nosing", or "sucking up in the hopes of getting sponsored". Because of this ridicule that goes on in these forums, its hard to get pros and cons of one particular item with any objectivity.
Old 02-19-2012, 11:33 AM
  #1255
well once i upgrade i'll give another one a try, i did not install the one that failed on me so i have no idea, it was on the car when i bought it along with a bunch of other stupid crap, i spent the first summer with this car taking things out of it and fixing hacked wiring issues. so judging by some of the work i had seen in my car its possible it was installation error for sure. my car had something like 35 owners on the used car package too.
Old 02-19-2012, 11:51 AM
  #1256
No-Traction = Fun
CaliforniaDad's Avatar
That happened to me on a stock ignition rotor, the screw fell out and tore everything up inside. I now use a lock washer on mine.
Old 02-26-2012, 07:53 AM
  #1257
No-Traction = Fun
Little Update:
I started to notice a little oil leak coming from the cam/valve cover area. Took of the valve cover and after close inspection, found the intake camshaft seal was leaking. So at this point since the cams were going to have to come out I decided to go ahead and re-torq my ARP head studs. And after pulling everything apart its a good thing I did because I found a few that at loosened up a bit. I guess with heat cycles and what not. So I replaced the cam seals, cam cap seal, valve cover seal, spark plug seals. Put it all back together and no leaky leaky yet.
Old 02-26-2012, 08:05 AM
  #1258
sanman000719's Avatar
msd fails period i went through 3 of them then sat down and thought about it, and was like well its reoccuring, they cost about 450 a pop, and i could have had a m&w pro kit by now so thats what i did. the m&w has not failed me in the past 3 years
Old 02-26-2012, 08:11 AM
  #1259
No-Traction = Fun
Originally Posted by CaliforniaDad
Okay so using "TheShodan's" advice I can go 2 ways
Option#1
Mallory HyFire 6 EZL Digital CD Ignition
MSD Modified Cap & Rotor
MSD 8.5mm Super Conductor Spark Plug Wires
Grand Total ($369.85)
[/SIZE][/B]
Im a bit confused on why there is a coil tower coming off the mallory box? shouldn't the coil wire just go from the external coil to the MSD cap??
Old 02-26-2012, 09:19 AM
  #1260
Moderator
TheShodan's Avatar
You do realize that even if it died you could have sent it back to MSD under their warranty rebuild, right? I think the only thing I paid was shipping when my MSD Digital 7 arched.. I sent it in, paid $50, and it came back to me new. Worked so well, i gave it to my brother for his project.
I do see where you're coming from, don't get me wrong, but I'm just surprised that someone like yourself who doesn't take **** from anybody, didn't think of calling them up and getting the unit rebuilt for next to nothing, once it failed.
Old 02-26-2012, 11:07 AM
  #1261
im just gonna stay stock until i have a reason to replace it.
Old 02-26-2012, 05:50 PM
  #1262
No-Traction = Fun
hello? anyone?
Old 02-26-2012, 05:52 PM
  #1263
Moderator
TheShodan's Avatar
hello? anyone?
This one I can't answer, because I just went by the wiring instructions. Call summitt on their phone support. They'll go through it all with you if you think it'll work for you or not. I simply went by their instructions (me and a wiring buddy,) and put it together.
Old 02-28-2012, 08:07 PM
  #1264
No-Traction = Fun
Well I talked to an MSD tech today, and for my ignition system here is what he suggested and I ordered this.
MSD Black Wires
MSD HVC Blaster 2 Coil
MSD 6AL
Old 02-28-2012, 08:12 PM
  #1265
Moderator
TheShodan's Avatar
I have that exact same external coil, but DO NOT GET THAT MSD 6AL!!! Don't do it, man... I'm tellin' you..!!
Old 02-28-2012, 08:15 PM
  #1266
No-Traction = Fun
I also picked up A Modified OBX LSD (washer/bolt upgrade) de-burred, and shot peened. I also ordered the Syncrotech Carbon syncros 1-5 and a full honda transmission bearing and seal kit.
Old 02-28-2012, 08:17 PM
  #1267
No-Traction = Fun
I already have it. The tech I talked to at MSD told me there is no real advantage to go with the digital if I already have the analog unit already installed.
Old 02-28-2012, 08:19 PM
  #1268
Moderator
TheShodan's Avatar
well, good luck. I had one of those. worst ones ever. But the external coil was awesome. Still have it on my N/A car.
Old 02-29-2012, 01:29 PM
  #1269
speaking of transmissions im curious, what tranny do u run shodan?
Old 02-29-2012, 05:14 PM
  #1270
crvtectim's Avatar
He runs an LS with a 1.266 final drive so he stays in boost the longest.
Old 02-29-2012, 09:53 PM
  #1271
Moderator
TheShodan's Avatar
LS Transmission with a GS-R 3rd Gear , 4.785 final drive and Cusco 1.5 way LSD. Crazy, I know, but a perfect match for Lime Rock, Beaver and Mid-Ohio.. Not so good for Gingerman, waterford or Mid-America.
Old 02-29-2012, 09:54 PM
  #1272
Moderator
TheShodan's Avatar
mmmmmmm k..
Old 02-29-2012, 11:47 PM
  #1273
rich7777's Avatar
How random lol, is this your daily driver ? If so how many miles have you had out of that plate diff ?
Old 03-01-2012, 04:55 AM
  #1274
crvtectim's Avatar
mmmmmmm k..
Lol, gotta keep the fallacies rolling. Gives me an edge. :]
Old 03-01-2012, 06:15 AM
  #1275
Moderator
TheShodan's Avatar
Huh? Your statements are not making any sense right now. please elaborate, if relevant.
Quick Reply: My B18C1 Engine Build/Assembly
