94 Civic EX - is my engine interference or non-interference?
Old 06-09-2011, 10:52 AM
chevyd's Avatar
Icon2 94 Civic EX - is my engine interference or non-interference?
Sorry if Im a little car "stupid" this is my hubbys car but he is not sure of the answer either.
We have a 1994 Honda Civic ex 1.6l VTECH SOHC. We believe our timing belt went out and were wondering if we had an interface engine or a non interface. I can not find any info about this in google or other search engines so any help is greatly apprecitated!
thanks so much!
Old 06-09-2011, 10:57 AM
EJ1_CRIS_909's Avatar
Default Re: is my engine interface or non interface?
Interferance. I believe most, if not, all of hondas engines are interferance engines.
Old 06-09-2011, 11:24 AM
H-T White Ops
NOFX's Avatar
A lot of times if you look up the timing belt for the car there will be a note saying if that application (the vehicle) has an interference engine or not.
As I remember, all D-series engines (those are the SOHC engines usually found in '92-'00 Civics) are interference engines. I actually believe this is true for all Honda-built engines, though some of the engines used from other manufacturers are non-interference.
Btw, that engine should be, if it's the original engine, a D16Z6. This will be stamped on the front of the block, just to the vehicle's right of the header. This engine came in all '92-'95 Civic EX and Si trims, and also the '93-'95 del Sol Si.
Even if you decide to swap in another cheap engine, there are other options as well.
Old 06-09-2011, 12:02 PM
chevyd's Avatar
how would i be able to tell if anything was damaged when the belt went out? we were driving and it started popping/backfire sounds and then just died and we couldnt start it. we have been told that is the timing belt. Does that sound right?
Old 06-09-2011, 12:11 PM
Pull the valve cover off, then the upper timing belt cover, and you should have more than enough room to inspect the timing belt.
Old 06-09-2011, 12:52 PM
1988montecarlos's Avatar
the timing belt on the B18B in my civic snapped but i got lucky and there was no damage, if i were you id line up the timing marks and put a new belt on it and see if it runs fine, if i wouldve done that i wouldve saved myself time and money for the new headgasket/head bolts to put the head back on
Old 06-09-2011, 12:53 PM
98greensi's Avatar
this is true but the easiest way is just to take the distributor cap off and look to see if the rotor is turning while cranking over the motor
i had a timing belt blow on me in my old motor and everything is fine, so u take a chance and buy the belt, possibly a new water pump while u have it apart and try it. the only other way is to take the head off, and look for bent broken stuff. but then you are into a bigger more expensive job
Old 06-09-2011, 01:01 PM
But if it may have skipped broken teeth, turning it over could result to damage to the engine that may not already have. The *safest* way is just to pull the vc and tb cover.
Old 06-09-2011, 01:26 PM
Former User's Avatar
It's an interference engine. Install a new timing belt and then compression test the cylinders. For some reason, engine damage does not always result when the timing belt slips or snaps.
Torontopaul
02-14-2018 08:07 PM
Otis B. Firefly
14
02-09-2015 03:03 PM
SlowDriver74
11-17-2011 04:21 PM
Kcaustin23
Northeast (Sales)
10-05-2007 03:29 PM
RISING SUN RACING
01-14-2003 07:21 PM
Quick Reply: 94 Civic EX - is my engine interference or non-interference?
