blue/white smoke from exhaust
Old 04-20-2011, 02:37 PM
AH419's Avatar
Default blue/white smoke from exhaust
i have a 91 civic HB and found oil leaked into the spark plug cylinders. i replaced the gaskets and oil hasnt leaked back into any of them. i replaced spark plugs and wires, and big clouds of white smoke is coming out when driving and mainly just shifting.
some say its coolant that leaked in due to HG failure
some say it may be oil burned
my radiator is leaking and coolant level dropped slightly after white smoke.
could it be the HG? how do i know if it is the HG for sure?
any feedback will be great
Old 04-20-2011, 03:52 PM
frankenghia's Avatar
Default Re: blue/white smoke from exhaust
If you are loosing coolant and its not visibly leaking out then there is a good chance you have a blown hg. You can do a leak down and compression test to know for sure... Any oil in the coolant or coolant in the oil? Not always the case but a dead give away.
Old 04-20-2011, 03:59 PM
98ekb16's Avatar
White smoke=burning coolant
Blue smoke=burning oil
Sounds like your headgasket may be on it's way out. +1 for a compression test
Old 04-20-2011, 04:03 PM
Seagull Management
94EG8's Avatar
Thread moved to the '88 - '91 Civic/CR-X section.
Old 04-20-2011, 04:25 PM
Garcia505's Avatar
Same thing happen to me replaced the the hg and it solved the problem but now my valve head gasket is leaking sad lol
Emmanlumb
03-22-2016 10:59 AM
whatala
09-26-2006 12:10 PM
djstain
06-01-2006 09:58 PM
VvPeachyvV
14
12-09-2004 06:38 AM
extrmeboost
06-13-2003 08:00 AM
Quick Reply: blue/white smoke from exhaust
