From Dirty to FILTHY
Old 03-20-2011, 05:47 PM
Mike Jones
SlowPokeEg's Avatar
Default From Dirty to FILTHY
In the beginning, there was the Dirty D:
https://honda-tech.com/forums/appearance-build-threads-122/dirty-d-eg-si-build-pull-up-seat-picsx10000-2289092/
Now that the motor has been boosted for almost 6 years, the motor is finally showing it's age. Time for a rebuild. about 3 years ago I bought a spare Z6 motor, preparing for just this occasion. Lets see where this goes shall we?
The teardown (started today)
This thing was leaking and smoking out of every which fitting/hole/crevice.
Front bumper has seen better days. I wonder if a body guy can plastic weld this up?!
Long story short, I took my spare motor to a NE Ohio builder (who specialized in Hondas) and he Effed my A. Took the motor up there last June. Told him to stop working on it in October. Finally picked it up in JANUARY. Took it to a local engine builder to finish it. The motor is done and waiting pickup.
This build consists (so far) of:
-D16z6
Bored,honed, notched, FJT Turbo kit. Valve guides replaced on stock head
Go-Autoworks Mini-Ram turbo manifold
Edelbrock y8 Intake Manifold
AEM Fuel rail/FPR
GSR 60mm TB
Precision 880cc Injectors
Go-Autoworks Charge pipe kit
Still a lot to buy!!
I think I'm going with a .48a/r T3/T04e 57trim Garrett. Thoughts?
Old 03-20-2011, 05:54 PM
didurgf's Avatar
Default Re: From Dirty to FILTHY
about time you make a build thread...
Old 03-20-2011, 05:55 PM
Mike Jones
SlowPokeEg's Avatar
This weekends plans include:
Minor wire tuck. Remove fenders, run Headlight wiring through fenders. Try and tuck some other wires. Suggestions?!?! No cutting/lengthening if I can.
Once that is done, we're going to mark some of the unused holes for filling.
Next: Blown motor gets pulled
Get to work on prepping the bay for paint
Old 03-22-2011, 07:02 PM
Mike Jones
SlowPokeEg's Avatar
Snapped some pics of my parts that I had stored in my garage attic.
Blox Sandwich Adapter
Go-Autoworks Vac Mani, and AEM FPR
Tial Wastegate
Tial BOV
Lovely Go-Autoworks Mini-Ram manifold
And the beast. Edelbrock Intake Mani, AEM Fuel Rail, Jegs Pressure gage.
Old 03-22-2011, 07:38 PM
The Ogre's Avatar
nice
Old 03-22-2011, 09:37 PM
hamizle's Avatar
what kind of power are you looking to make? that turbo is a decent size for that motor
Old 03-23-2011, 04:35 AM
Mike Jones
SlowPokeEg's Avatar
Looking to put down somewhere around 340whp, with room to grow to 400 if and when I decide to build the head.
I'll be driving it quite a bit, so as long as the tune is safe, if it only makes 320-330 I'll be happy!
Old 03-23-2011, 08:11 AM
sde780's Avatar
Was it a stock z6 from before? How much power were you making?
Old 03-23-2011, 08:12 AM
hamizle's Avatar
that should be fine, are you doingor e85?
Old 03-23-2011, 08:22 AM
Mike Jones
SlowPokeEg's Avatar
Previous setup was a bone stock Z6. 450's, 255 Walbro, T25 turbo, Head studs.
Put down 266whp
I'm throwing around the idea of Water/Meth right now to be safe.
Old 03-23-2011, 08:54 AM
hamizle's Avatar
i ment to say are you doing pump or e85, water/meth would be a good idea as well, with your upgraded fuel sys you wont have problems im curious to see what power you make at ?psi i have never played with the dirty d's but they are making power these days
Old 03-23-2011, 10:48 AM
javiDC4's Avatar
looking good, gotta love that green!!!
Old 03-23-2011, 11:58 AM
G.E.C.-Manny215's Avatar
Niccceee mann
Old 03-23-2011, 12:18 PM
Mike Jones
SlowPokeEg's Avatar
It's amazing where the aftermarket has taken these D's. It used to be 250-300whp max. Now the sky is the limit. With Bisimoto and Go-Autoworks supporting the D's, it's a good time to be a D!!
Like I said, I'm shooting for 350whp on pump. I'll see how far I can go with water/meth before it gets squirrly. I just want a good/safe tune. Not out to make crazy HP numbers. 350whp in an EG hatch is going to be scary enough!
Next up (once it warms up), Fatmat the shell!
Old 03-25-2011, 08:32 AM
hamizle's Avatar
theirs a shop over here thats getting into them some are using those vitara pistons and have been able to build their motors super cheap, its tempting to try. 350 in a hatch will be plenty for daily use. get us some more pics!
Old 03-25-2011, 08:54 AM
Mike Jones
SlowPokeEg's Avatar
Mini-Wire tuck tonight.
Then pull the motor
Also, bringing home the built engine today! SUPER pumped. Might start mocking stuff up on it.
We so excited!!!!!!!!
Old 03-27-2011, 08:11 AM
Mike Jones
SlowPokeEg's Avatar
Some major work getting done this weekend!
Parts piling up!
Some lazy kids
Motor is out! No cherry picker...good thing I have big friends lol
Told you they were lazy. Wame blacking out
Started mocking stuff up on the new motor!
Old 03-27-2011, 08:24 AM
Mike Jones
SlowPokeEg's Avatar
Next up....Making this look a LOT nicer
Old 03-27-2011, 10:28 AM
Mr. EG's Avatar
Good job so far!
Old 03-27-2011, 11:16 AM
cbustuner's Avatar
You should have no issues getting the numbers you want.You and I have almost the exact same build..same IM ,same turbo manifold, same T/B size , same turbo (mine has a .63 ar turbine housing), same pistons. Good luck with everything!
Old 03-27-2011, 01:15 PM
Mike Jones
SlowPokeEg's Avatar
Thanks folks. Wifey stole our Digi-cam for the weekend so I havn't been able to get many pics. Firewall is pretty bare now.
Trying to decide what to do with fuel lines/brake lines. Tucking would be nice but that will just end up being expensive and very labor intensive.
Also, pondering just putting a manual rack in. I've heard you can run the PS rack, but I'm not so sure about the longevity of it.
Wiring harness work starts wed. Bringing in an experienced veteran to lend a hand. Hopefully this mini-tuck doesn't get too crazy.
Next up - Get the car painted!
Old 03-27-2011, 05:31 PM
Flattery Will Get You Everywhere
markspan6243's Avatar
i want this thing to be at IA 11
Old 03-27-2011, 05:41 PM
Mike Jones
SlowPokeEg's Avatar
9 Hour drive? I'm afraid that's asking a lot lol. I WILL, however, be at h2o in Ocean City. Traitor I know, but there's a large VW following and I'm good friends with many of them.
Old 03-27-2011, 05:46 PM
lol damn i live in dayton, wanted to get as many ohio people to go!
Old 03-27-2011, 05:52 PM
Mike Jones
SlowPokeEg's Avatar
I hear ya man. Ohio needs to show up a little more!
Quick Reply: From Dirty to FILTHY
