EG / DC Front Subframe into EK
Car: 1999 Honda Civic Si
My plans are to swap in an Integra P/S rack and EG / DC subframe. I've searched but there isn't a whole lot of good information on this. The car has P/S currently and a B-Series motor. I want to make sure that first off the swap will work and second that I have the correct parts list.
From what I understand:
EG / DC Front Lower Control Arms (the Si ones won't work?)
EG / DC Compliance Bushings
ANY EG / DC Subframe (that has P/S)
The Rack Itself
Is this correct? Also, will the front geometry be off in any non-alignment correctable way?
Thanks.
The Rack Itself
Thanks.
Re: EG / DC Front Subframe into EK
Sence your going to be in there, rack bushings, tie rods would be a thing.
It will be so much easier now, than down the road when its in the car.
But your list looks fine to me.
I've actually recently replaced both the tie rods and upgraded to the stiffer ITR rack bushings. This was before I knew I'd be swapping racks, but either way it's already done and it's one less thing to do.
That was my last question too was the lines? I could've sworn they are at a different angle on that valve?
Seagull Management
Nope, and uh, neither is the pump. You'll need a '92 - '95 Civic P/S pump bracket and a '92 - '95 Civic or '94 - '97 Integra P/S pump (both are the same) All lines need to come from a '94 - '97 Integra, so does the reservoir (I found this out the hard way when I swapped an Integra rack into a '93 Si) Ideally get the subframe from a DC Integra, '92 - '95 Civic is basically the same, but the Integra has a nice stiffening bar (the bar will bolt on to civic subframe though, the holes are there for it.
Also, yes you can use an ITR rear rubber mount.
I want the quicker ratio of the Integra rack. I know that people that are swapping the Integra internals (the pinion gear to be specific) in the EK rack, however it's been made known that the splines are thinner on the DC internals and that this would cause pre-mature wear overtime. The other option is to swap the pinion gear AND internal rack of the Integra, but the one guy that did that said it caused a negative impact on his turning radius (something came up shorter?)
This seemed to be the best method with no issues, but may be way too involved after all.
I work @ at a Honda dealer so I'm not concerned about a lift / tools / labor. It's just if there are THAT many parts to change it's not worth it IMO.
I daily the car.
From research it seems as those the low pressure line will work, but I need to find a high pressure hose. Is there a high pressure hose that fits a 99-00 Si P/S Pump and works with the conversion?
I suppose I could just loop the P/S but I want to make sure there's a line that would work in case I end up selling the car (I'd hate to have to swap racks back just to gain P/S).
I daily the car.
Seagull Management
Didn't realize this was an Si. '98 - '01 Integra lines should work with an Si P/S pump. If it's anything like the '92 - '95 Civics you'll need to change the return lines and reservoir as well.
The return is a softline so I should just be able to cut a hose to length. If the high pressure hose is all I need to add to the list then I'll probably still consider it.
Would you say it's worth it knowing what I'm about to put into it parts / cost wise?
Seagull Management
If you're tracking the car probably. It's definitely quicker, Like I said I swapped mine but I haven't driven the car on the road since, just around the yard so it's hard to make a good comparison.
I still think I'm going to go for it. It's ridiculous, the EK has absolutely the worst steering rack / ratio compared to most all Hondas. The Del Sol, EG, EP3, RSX, CR-X etc ALL have better ratios.
I need to figure out the lines though?
I figured out the lines, I'll use the Integra high pressure and just use a rubber hose (custom) for the return line.
I'm ordering misc. bolts and whatnot for the swap and my question is for the FLCA do I need both washers for the compliance bushing in this pic?
The EK FLCA arms that I'm using only use one washer on the rear side, do I need to order the front ones since I'm using the EG / DC compliance bushings?
