91 si intake manifold
Old 02-20-2011, 07:53 AM
jsinher3's Avatar
Default 91 si intake manifold
im doing a mpfi swap on my 91 civic dx and had a few questions;
does anybody know where i can find the vac hose diagram for the si intake mani?
do i need a si distributor or can i just use the one i have?
do i need a si throttle body cable or can i re use the one i have?
sorry if these answers have been asked i tried searching but i cant seem to get the answers im looking for.
Old 02-20-2011, 08:20 AM
Mr.Cheezil's Avatar
Default Re: 91 si intake manifold
Here is a list of everything that you will need. GL
http://hondacrx881.tripod.com/mpfiswap.html
Old 02-20-2011, 08:35 AM
jsinher3's Avatar
i checked the site out but i just want to know if its really needed or can i reuse what i have
Old 02-20-2011, 08:38 AM
jlicrx's Avatar
you need the distributor from 88-91 CRX Si or HF, 88-91 Civic Si or EX - can't use the DPFI distributor
although it looks a little cleaner to use the Si throttle cable, you don't have to use it - you can use the DX cable by just looping it out around the strut tower
here is 89-91 (not 88) Si vacuum diagram:
Old 02-20-2011, 08:50 AM
KINGVEM^^ED6's Avatar
dont reuse ur dx cable just get a si one there cheap
Old 02-25-2011, 08:30 AM
jsinher3's Avatar
thanks quick question.. if i decide to keep the dx distributor would the car still function the reason why im hesitating in getting the si distributor is because im not keeping this motor im just trying to get the wiring done and get it 100% running right for when i drop my b20 in...
Old 02-25-2011, 09:13 AM
dephtone's Avatar
No you cannot use the DPFI distributor. The DPFI distributor does not have some of the sensor the MPFI ECU needs for the car to operate properly.
Old 02-25-2011, 09:30 AM
jsinher3's Avatar
okay thanks does anybody know what other distributor i can use besides the 91 si i think its stamped td02..
Old 02-25-2011, 10:03 AM
u can use a obd0 ls one but only one bolt will line up
Old 02-25-2011, 10:12 AM
jsinher3's Avatar
does anybody else know if this will work? again all i want to do is make sure the wiring is done right and everything will function correct when i drop the new motor im not keeping the d16 and im not using this as my daily driver so that is why im trying to avoid ditching 120 up for a si dizzy...
Old 02-25-2011, 10:57 AM
BiG ChOr!Zo's Avatar
td-18u
Old 02-25-2011, 11:58 AM
it will work iv personally ran it cuz the mpfi dizzy i got was shot
Old 02-25-2011, 01:28 PM
jsinher3's Avatar
do you know the distributor stamp code for the obd0 ls dizzy?
Old 02-25-2011, 01:40 PM
jsinher3's Avatar
can i use a obd1 converted to obd0 dizzy?
Old 02-25-2011, 04:53 PM
Keyboard Humorist
4drEF's Avatar
How do you do that?
You can't just swap plugs.. it won't work. The reluctor wheel in the dizzy has a different tooth count and will send the ECU the wrong signal.
Old 03-03-2011, 08:35 PM
jsinher3's Avatar
thanks for letting me know that..
does anybody know how i can tell is a dizzy is from an 91 si or not im trying to buy one of someone but hes not sure if its off a si or not and cant find the stamp code td02u on it, can you tell by the electrical pins in the plug or something??
Old 03-03-2011, 08:44 PM
it will be stamped with either td-02u or td-18u on one of the metal arms...!!!
Old 03-04-2011, 04:04 AM
jsinher3's Avatar
he cant find it, its not on the legs he cleaned it and couldnt find the stamp it must have just fadded with time..
Old 03-04-2011, 01:44 PM
td-o1u-will have a small square clip
td-02u & td-18u-will have a bigger round clip
Old 04-22-2014, 08:32 PM
ktay1990's Avatar
what about if i have an msd pro cap dizzy?
TheSaianITR
10-06-2002 08:15 AM
civic2299
05-07-2002 05:49 AM
allmotorEG-SI
10
03-31-2002 10:13 PM
iceman_pl
05-06-2001 05:06 PM
Quick Reply: 91 si intake manifold
