Stock Map Fuel Maps
Old 05-22-2011, 08:56 AM
alperx's Avatar
Default Stock Map Fuel Maps
I see the p72 Stock Map Fuel Maps are not straight.
Look at the marked area. The numbers get bigger and smaller and bigger again.
What is the point at that ?
Old 05-22-2011, 09:14 AM
mtber's Avatar
Default Re: Stock Map Fuel Maps
There is less fuel being injected in that rpm & load range due to the motor needing less fuel in that rpm/load range.
This does not apply on all applications, that is the way the stock curve looks...
Old 05-22-2011, 09:33 AM
alperx's Avatar
I mean isn't it a bit out of logic ?
Old 05-22-2011, 11:37 AM
GhostAccord's Avatar
What logic? It's not according to Acura/Honda's dyno tested logic.
Look at the area you have highlighted, as mtber mentioned, that is an off the throttle cruising area of the maps. No need for extra fuel in a no load & low rpm situation. Best to lean it out a bit to save fuel.
norcalB18
Engine Management and Tuning
12-03-2015 08:46 PM
Pssst!
04-06-2011 09:36 PM
B18Tahtaras
07-07-2005 12:06 AM
Propulsion
01-10-2004 10:02 AM
Shft@9GSR
12-12-2002 09:56 AM
Quick Reply: Stock Map Fuel Maps
