need help with hoses on skunk2 manifold
Old 02-25-2011, 02:38 PM
ayeta91's Avatar
Default need help with hoses on skunk2 manifold
im going from jg manifold to skunk2 so im missing some hoses and having trouble figuring out where some go! heres some pics
its hard to see in the pic because its under the fat hose. so i drew a little pic of what it looks like on the side view
Old 02-26-2011, 10:15 AM
Mindgamez's Avatar
Default Re: need help with hoses on skunk2 manifold
First Pic, Hose goes from the TB to the Little black box that you have an open hose thing on Pic 2.
Pic 3 Not sure what that is, Its not your map what is it?
Pic 4 you have to plug that hole, Its not used.
Pic 5 Either plug it or it runs to something on the firewall.
Old 02-26-2011, 12:57 PM
14baldo66's Avatar
this is the way my mechanic did it
the inner hose went to breather box and intake manifold, he use a "T" to split the lines
Old 02-26-2011, 04:59 PM
ayeta91's Avatar
thanks!
Old 03-02-2011, 07:34 PM
ayeta91's Avatar
i got one last question for pic 4 with that tiny hose that has coolant running through it. what did you guys use to plug it? i thought a little rubber plug woulda worked but it shot out lol right now i have a hose connected to it with clamps and plugged the other end of the hose with a screw and clamps
Old 03-03-2011, 06:53 AM
madmax94's Avatar
For pic 4, I used a small vacuum line with a screw but no clamp. You should be fine.
This might help for the other stuff:
http://www.performanceforum.com/wesv...k2/skunk2.html
Old 03-03-2011, 07:00 AM
madmax94's Avatar
If pic 3 shows the EVAP purge control valve you can move it to the nipple in pic 5 like the guy did in the link above.
shadycrx
01-01-2006 09:10 AM
shadykit
03-25-2005 04:05 PM
z6
06-14-2004 03:01 PM
Projekt20
08-29-2002 10:44 PM
GreenD
05-20-2002 09:29 PM
Quick Reply: need help with hoses on skunk2 manifold
