Power Steering Pump replacement failed
Old 03-09-2020, 10:59 AM
SNAKE_15's Avatar
Default Power Steering Pump replacement failed
So noticed that it was super hard to turn steering wheel mostly on cold starts so I replaced the pump from o'riley. No change, when I turn steering wheel and it freezes up, I noticed the pulley on ps pump freezes up as well causing the hard turn
I already tried two ps pumps from Oriley, 2nd pump felt a little better but pulley still freezes up when I turn the wheel. No leaks and I did a complete ps flush
Also pulley is all lose when car is running and I torqued to spec the nut. I posted a video but not sure if you guys can see the attachment
Old 03-12-2020, 09:46 AM
r_kage's Avatar
Default Re: Power Steering Pump replacement failed
Hi, did you figure out the problem?
Old 03-12-2020, 09:51 AM
SNAKE_15's Avatar
I haven't worked on it yet. Planning to try a different brand pump and see if it changes
Old 03-13-2020, 06:14 AM
99stockcivic's Avatar
Could the steering rack be what's actually causing the problem here?
Jeremiahpdx
09-20-2019 02:29 AM
jmrec100
03-21-2016 05:15 PM
johnny_honda
03-02-2011 06:15 AM
sivikvtec
07-30-2008 07:42 PM
E.Honda
12
05-24-2007 01:41 PM
Quick Reply: Power Steering Pump replacement failed
