HELP driver door will not open from either side?
Old 12-11-2010, 01:23 PM
BLeSR's Avatar
Default HELP driver door will not open from either side?
i opened it like five minutes ago and now it won't open from either inside or outside
i have a 95 honda civic dx manual windows and doors anyone know how to fix this?
Old 12-11-2010, 02:00 PM
AutoXer's Avatar
Default Re: HELP driver door will not open from either side?
What exactly is it doing? Does it feel normal when you pull the handle? Does the lock feel like it's working normal? Any noises?
Old 12-11-2010, 02:23 PM
h22accord101's Avatar
sounds like the rod that goes from your handles to the door lock has came off maybe
Old 12-12-2010, 10:18 AM
BLeSR's Avatar
yea locks are working fine no noises or anything its just not opening im pretty sure it has something to do with the lock hinge. all the the long thin metal rods are still intact but still will not open. i just want to find a way to get the door open any suggestsions?
Old 12-12-2010, 10:54 AM
2000siturboR's Avatar
whats wrong with the dukes of hazzard method?
Old 12-12-2010, 11:57 AM
can you not reach in and pull the rod cause if the rods are moving properly it should open have you tried shoving on the door as you try to open to make sure it isnt jammed up
Old 12-12-2010, 03:15 PM
AutoXer's Avatar
This is a tough one... I've never come across where both handles didn't work. It's going to be tough to get this open since you can't get the door card off with the door closed, and you need to get to the internals. I'm stumped, so bump for you.
Old 12-13-2010, 07:22 AM
BLeSR's Avatar
ive tried pulling the rods i was able to get the door panels off i have tried everything to get it unlocked.
it maybe be jammed by something. i recently washed the car and water does leak in so that might be it?!?!
Old 12-13-2010, 08:36 AM
wellas you try opening the door shove on it real hard and yea its a hard one ive never heard of ine not opening with eaither handle unless rods where off to the lock if that dnt work get some dicer and spray in to the lock if you can
Old 12-13-2010, 08:39 AM
g35silversurfer's Avatar
weird.... bump.
Old 01-04-2011, 01:36 PM
tperry5's Avatar
@BLeSR,
did you ever solve this problem? I am having the same troubles and can't get my door open!
Old 01-04-2011, 01:40 PM
91efbluehatch's Avatar
strap a come along to it. and rip the bisch off.
this is wierd. had this happen on my 99 accord.
check the plastic bushings that connect the rod to the handle and so forth.
Old 01-04-2011, 02:26 PM
sublime423's Avatar
Sounds like a bad latch. Which can be a pain in the *** because you will have to take the door panel off inside the car and drill the latch out. I hate it when that happens it is not a fun job.
Good luck
headdles
12-09-2014 12:20 AM
M2B4
02-03-2009 10:38 PM
tadashisan
10-13-2008 07:55 AM
ten_30
03-01-2004 09:11 AM
NONKonformyst
09-22-2002 11:34 AM
Quick Reply: HELP driver door will not open from either side?
