P0135
Old 12-10-2010, 03:48 PM
Offspring EK's Avatar
Default P0135
Hello all,
So my dx threw the MIL light a couple days ago and im able to scan codes at home and P0135 was the culprit. Fast forward to today, i replaced the 02 with a Denso replacement ONLY because i wasnt having the speedo issue/etc that came with the popular blown fuse. I pull the 7.5 Backup fuse to reset the code and the code returned 5 seconds after start up. Should I let the car go through some warmup cycles or does my problem run deeper?
Old 12-10-2010, 03:51 PM
Former User's Avatar
Default Re: P0135
Is fuse 15 blown?
Old 12-10-2010, 03:56 PM
Default Re: P0135
Originally Posted by RonJ@HT
Is fuse 15 blown?
Going by looks alone at the moment, i would say no. Do not have a test light currently.
Old 12-10-2010, 03:59 PM
Default Re: P0135
A test light costs about $2.
Old 12-10-2010, 04:02 PM
Default Re: P0135
yea ill be grabbing one in the morning. could have sworn i had one but i cant find it anywhere.
Old 12-11-2010, 09:45 AM
Default Re: P0135
welp its busted. gotta do the TSB. Although I went out and bought another couple 7.5A fuses and they are too big. Annoying. I grabbed ATO size fuses and I'm assuming the 7.5A Fuse 15 is a "mini fuse"?
Old 12-11-2010, 10:48 AM
Default Re: P0135
Can anyone confirm that the fuses are the mini size?
Old 12-11-2010, 11:14 AM
V.MoMO's Avatar
Default Re: P0135
im pretty sure they are but if not why not got to the parts store, pull one or take the blown one and just compare them inside the store.
you said u got the wrong ones, if ur returning them then might as well do it all in one trip
Old 12-12-2010, 05:36 AM
Default Re: P0135
Update:
-Replaced fuse
-Reset ecu (pulled 7.5A backup)
-MIL appeared again on startup
-checked fuse to see if it had shorted again, and it was still good.
Old 12-12-2010, 11:14 AM
Default Re: P0135
Measure the resistance across the O2 sensor terminals for the heater element.
Old 02-01-2012, 06:59 AM
Default Re: P0135
Problem has been fixed. New sensor and a reset got rid of the CEL. Thank you for the assist H-T.
dansaleen_04
07-22-2013 11:19 AM
Cdeese910
10-25-2012 07:56 AM
96 EX
05-14-2010 07:05 AM
guywitaDA
04-21-2004 09:58 PM
Quick Reply: P0135
