How Do You Propely Remove the Driveshaft on the CRV
How Do You Properly Remove the Driveshaft on the CRV
I need to swap out a trans and was wondering how exactly do you remove the drive shaft on my '01 Crv
Thanks for any help!
Re: How Do You Propely Remove the Driveshaft on the CRV
when i had to replace my trans 7,000mi ago all i did for the driveshaft was unbolt the 4 bolts on the transfer case/center diff. and let it hang down.
hondaautomotiveparts.com says "(12POINT 8X21)"
I tried a 10mm and 11 mm. 11 was too big and 10 too small it seems.
be professional
Uh, not to be offensive, but are you really prepared to swap a transmission? Unbolting the driveshaft is one of the simplest steps...
