> Audio / Security / Video
Old 11-23-2010, 04:16 AM   #1
delta25
Default grounding kits and voltage stabilizers... why?
I'm considering upgrading my "big 3" wiring in my car (98 civic). However, I see alot of engine ground wire kits and voltage stabilizers on the market. So my questions are:
1) Is it worth having a VS, or is it tuner bulls**?
2) Does a ground wire kit make a difference?
3) Is a ground wire kit still functional if the "big 3" wires are swapped to 0 gauge?
delta25 is offline   Reply With Quote
Old 11-23-2010, 07:04 PM   #2
joeymc13
joeymc13's Avatar
Default Re: grounding kits and voltage stabilizers... why?
grounds make a positive difference, whether or not you have upgraded the big 3. The larger the wire, the less resistance to ground, so 0 awg wont hurt anything. I dont understand your question #3... If you swap to 0 awg, is that not the ground update kit you are referring to in the first place? I don't have an opinion on VS, I don't see an immediate benefit, nor do I see a negative on them.
"Freaky like my lady piramid!!!"... MECP Advanced mobile electronics tech, cert # CEA192513-ABYC certified marine electrician-NMEA certified marine electrician, cert #1068-FAA certified in avionics service & installation
joeymc13 is offline   Reply With Quote
Old 11-23-2010, 07:27 PM   #3
Cobb2819
2000 Honda Civic
Cobb2819's Avatar
Send a message via AIM to Cobb2819 Send a message via Yahoo to Cobb2819
some performance companies make all kinds of "ground kits" that are basically a bunch of little grounds hooked up to a ground distribution block.
as for the question...start with the big three.
Jacob
Team NWT v.1 - F-SOS Click Supporter
Cobb2819 is offline   Reply With Quote
Old 11-24-2010, 12:45 AM   #4
delta25
yes i am, to refine #3: i guess i'm asking if once i upgrade to 0 gauge, is it still beneficial to have a ground wire kit? if the engine already has a 0 gauge ground wire on it?
Old 11-24-2010, 12:56 AM   #5
Eran
HT White Ops
Eran's Avatar
iTrader Rating: (1)
Interesting story about grounding kits:
When I was a ricer, I did a grounding kit on my car. Made them with gold connectors and 0awg wire. And you know what? It made a difference I could feel. Idle was more stable and acceleration was improved.
Later, when I was done having red wires going everywhere in my engine bay .... I bought brand new grounds from Honda. Replaced all the 0awg grounds, and goddamnit if I didn't notice a bit of difference.
Lesson learned: I was a ricer and your stock grounds get corroded and nasty. Butt dyno does not equal power.
JDMREVEREND / SEAN CORBETT IS A THIEF
[ CR-XTASY ][ Flickr. ][ anti|hero ][ dSoc:124 ]
Eran is offline   Reply With Quote
98, big, civic, difference, engine, gauge, ground, grounding, honda, install, kit, make, motor, stabilizer, voltage
