Distributor O-ring
Old 11-21-2010, 09:02 AM
shifts's Avatar
Default Distributor O-ring
I am going to change the o-ring since it looks like it may be the cause for my leak. I can only find two bolts to that hold the distributor. Is this correct? I am use to having 3 on the b-series is why I would like some clarification. Also, where do you guys recommend making the marks to line up so that the timing won't be off?
'00 Honda Accord EX 4 cylinders.
Old 11-21-2010, 10:51 AM
My02accord's Avatar
Default Re: Distributor O-ring
Not sure on what engines have which but I did a motor swap in my moms f22 accord with a jdm motor (obd1 tho so diff dizzy since it was diff year also) and one had a distributor with slotted holes (must mark it if u dont time it after) and the other didnt have slotted holes, so its pretty hard to mess up and it can only fit into the cam 1 of 2 ways so thats hard to mess up too....just remember which way the rotor is pointing (or make sure u dont move the rotor shaft while u switch o-ring)
Either way an easy way is use a black sharpie and color around the outside of one or more of the distributor bolts, so when it goes back in you know where it was and can just put the bolt head into the non colored part..or if afraif of it rubbing off make some scratch marks with a flathead or something..or just time it afterwards if youre able to....
Old 11-21-2010, 11:26 AM
shifts's Avatar
My main problem is that there is only 2 bolts that actually hold it to the head. The location of these two bolts proves to be a problem for drawing a mark.
Old 11-21-2010, 01:35 PM
My02accord's Avatar
Theres gotta be a mark somewhere where the dizzy mates to the head for a reference point that you can make...or just loosen the bolts while holding the dizzy and turn it left and then right and see where it is if its more towards the center of the holes or more towards one end....this is assuming it doesnt have the long slotted holes.
Old 11-22-2010, 06:08 AM
shifts's Avatar
Anyone else before I start on Wednesday?
Old 11-22-2010, 11:14 AM
brakedrum's Avatar
You'll have to get creative about marking the position. Use a paint marker because it can mark right on dirt and grime and show up well. Pay attention to where the dirt and bolt marks are as you remove the distributor. The will also help you bolt it back on precisely. Anyway, there's always somewhere to make a mark. Find it and mark it with the paint before unbolting.
Old 11-22-2010, 04:50 PM
nus_dogg's Avatar
Yup, scribed where you want on the distributor and somewhere on the engine side, so you can always line it back up when it comes to installing it back on.
Most Honda uses 3 bolt distributor.
Old 11-22-2010, 05:31 PM
onthe3rdday's Avatar
Your specific distributor has only 2 bottom bolts because the ecu controls all timing advance/ retard
Old 11-22-2010, 06:04 PM
shifts's Avatar
Meaning it'll automatically set the timing or?
Old 11-22-2010, 07:57 PM
ok, I'll start by saying, you can install the distributor incorrectly and then the car WILL NOT START. Make an effort to TDC the car OR take note of the position of the rotor prior to removal. Once the new distributor is in, it's set it and forget it!
Old 11-23-2010, 09:06 AM
shifts's Avatar
on me. After further inspection, there are no slotted holes so I can't adjust the timing from the distributor so this is simple job of just removing two bolts and then replacing the o-ring and screwing the two bolts back in. I am still going to note which location the rotor is pointing to and still find a place to mark just in case something unforeseen happens.
Thank you guys for all of your valued inputs. .
Old 11-25-2010, 06:37 PM
My02accord's Avatar
After more forum browsing I hear the distributor "tangs" are offset to help prevent from putting the dizzy in 180 degrees out. So if the dizzy takes alot of pressure to mate to the head its prob in 180 out.
Old 11-29-2011, 10:37 PM
koreboy's Avatar
I simply etched mine in using a ruler and a sharp metal object. Tired the paint, but I didn't think it was as accurate. Make sure you can see that marking well enough.
jmanuel
03-28-2021 09:26 AM
skhell
01-16-2018 11:37 AM
mellowman164
01-12-2014 10:59 PM
TAINO
05-27-2007 11:02 AM
LX4CYL
10
12-09-2005 06:06 PM
Quick Reply: Distributor O-ring
