Will it fit?
Will it fit?
Hey guys, I'm fairly new to the Honda game and I'm not too knowledgeable on the dimensions of engines and such. I've found a wrecking '01 Accord for $300 with only 150,000 miles on it and I would like to go for the build, as it will be my very first. I realize that the mounting of the f23a1(VTEC) and the f22b2(non-VTEC) are probably different, so there might have to be some fabrication involved. What do you guys think? Will it fit?
Re: Will it fit?
Just what are you trying to do?
If you are taking the 4 cyl from the 2001 and putting it into a 4 cyl 5th gen (94-97), then yes it will fit and has been done/covered/written about/documented.
Re: Will it fit?
You have a 5th gen Accord and want to put a newer, vtec motor in it?
Unbelievable....
There are many writeups on, this, with a little time and research, you can find what you need.
This may get you started in the right direction.
Accord Wagon Club ? View topic - F23A1 Swap
Unbelievable....
Re: Will it fit?
Yeah that's basically what I want to do, I just need to know if there are any specific thing I need to watch out for (i.e.- mounting, engine dimensions, etc.)
13g-crx
04-08-2015 11:10 AM
