harmonic balancer question
Old 11-07-2010, 08:17 AM
  #26
HonBeer's Avatar
Default Re: harmonic balancer question
WOW! Some people need to go back to high school and take basic physics equations all over again. Unless your a highschool drop out.
Old 01-03-2011, 09:30 AM
  #27
edogmb's Avatar
ok...just have to bring this one back to life...
After lots of work, I still have a pretty good vibration in my steering wheel at idle in gear. Parked there is very little vibration. At speed there is some occassionally, but I believe it to be the wheel balance. Anyway, I changed the rear mount twice...once with a solenoid, then one without... I also changed the front wishbone and side mounts. I changed my timing belt, balance shaft belt, tensioners, tensioner springs, water pump, battery, alternator, most vital sensors aside from MAP, complete tune up....the list goes on...
When all is said and done, I have a couple of possibile culprits in mind. My IAC seems to be not working correctly after replacing it a few months back with a used one. My rpms drop more with every additional accessory turned on, and when I unplug it at idle there is no rpm change.
My control arm and stabalizer bar link bushings are bad. Has anyone heard of something like this causing steering wheel vibration at idle??? I appreciate any ideas or suggestions. Thanx fellas.
I also just found that my cruise control isnt working...if that helps any.
Old 10-05-2012, 01:50 PM
  #28
RufusHonda's Avatar
Icon2 Re: harmonic balancer question
My bro replaced harmonic balance on 91 honda accord, belt kept coming off, once we replaced it had timing checked on top and bottom and it wont crank, you would think its about to fire up but it just sits and churns wont turn over can somebody help a playa out , top bolt is a bitch you will need an air rachet or rent one from your local Advance Auto or AutoZone they sell the electric ones, they work just as good.
NEw items:
-Starter
-Distributor(tested good) button and cap replaced just in case
-spark plugs and wires
-checked all fuel lines
-new battery
brother had the harmonic balanced replaced and afterwards havent been able to get it cranked alot of people tell me that the timing is off but my brother had the timing checked top and bottom and it still wont completely crank, it literally sounds like its about to crank but wont turn over, i was going to spray some injector cleaner in it tried it with my explorer one time and burned off my eyebrows can you help me out with some tips..
Old 10-05-2012, 02:09 PM
  #29
djkurious's Avatar
NEw items:
-Starter
-new battery
Had this happen before to my cousin. Check ignition timing and cam timing and make sure it is spot on.
sparkylawdog
05-28-2010 03:48 PM
JasonYo
04-03-2010 10:32 AM
ShinobiLude
11-08-2006 08:40 AM
llevity
07-12-2005 02:39 PM
harryg
05-08-2002 10:26 AM
Quick Reply: harmonic balancer question
