how to change driver side axle 96 Integra
Old 10-13-2010, 12:10 AM
No-Traction = Fun
CaliforniaDad's Avatar
Default how to change driver side axle 96 Integra
Here is a little step by step i put together on ( how to change the driver side axle shaft on a 1996 Integra GS-R) should be the same for GS/RS/LS models as well. I know for some this is easy to do, but others this might be a helpfull.
Thanks Enjoy.
Old 10-13-2010, 12:12 AM
No-Traction = Fun
Default Re: how to change driver side axle 96 Integra
Continued......
Old 10-13-2010, 12:14 AM
No-Traction = Fun
and the last part.............
Old 10-13-2010, 01:49 AM
OC_DC2_JDM>EURO's Avatar
always wanted to know how to fix one of those. good write up!
Old 10-13-2010, 07:36 AM
No-Traction = Fun
Thanks I'll write more as they come.
Old 10-13-2010, 08:49 AM
and nice garage lol personal lift?
Old 10-13-2010, 12:02 PM
No-Traction = Fun
Yep when I had my house built, I made sure I had my shop/garage factored in. hahaha. The wife gave me the thumbs up on it. As much as I mess around with cars I needed a lift and 20ft ceilings.
Old 10-13-2010, 12:22 PM
dntnedvtec's Avatar
Good write up, but you didn't tell the torque spec for the axle nut.
132 lbs ft.
Old 10-13-2010, 01:30 PM
1998GsRIntegra's Avatar
132 lbs ft.
Torque spec for axel nut= tighten it with the impact, then hit it once or twice more. If your really want to be exact then torque it. I did learn what the torque spec for an axel nut is though so to you for the info.
Old 10-13-2010, 02:48 PM
TOO MUCH TORQUE's Avatar
Excellent DIY..very clear and concise. Good pictures too!
Old 10-13-2010, 09:45 PM
No-Traction = Fun
Thanks guy's. Should this be a sticky maybe?
Old 10-13-2010, 11:45 PM
mouab18c1's Avatar
The way I do it is way easier. LOL Nice write up for new learners
Old 02-19-2012, 06:30 PM
:jdmshmaydm:'s Avatar
Icon2 Re: how to change driver side axle 96 Integra
Should the new axle just slide right down into the half-shaft? I got a new one and I lined it up but it won't go down. I pushed it pretty good but it always comes out easy, it never grabs and slots down. Wondering if I have the wrong axle for my Teg.
Old 02-19-2012, 07:05 PM
Just heard it might be the c-clip interfering. Will try again tomorrow.
Old 02-20-2012, 06:13 AM
e-em-one's Avatar
wow that's one sick garage! nice write up too!
Old 02-20-2012, 06:23 AM
98ekb18c's Avatar
I've always been told that when you tighten any bolt going thru a bushing, like the lca bolts, you should have the weight of the car on the suspension first so the bushing is prpoerly clocked. If you don't it may cause the bushing to fail faster. Great writeup otherwise.
michealda9
06-22-2014 02:51 PM
mwpowers
12-24-2008 11:36 AM
7808
05-26-2007 11:02 PM
baonest
07-11-2005 08:35 PM
Quick Reply: how to change driver side axle 96 Integra
