89LX sedan build
#307
Re: 89LX sedan build
Im using gauges from a 94 Integra. yea its an auto **** on the lever. its just sitting there but IMO its better than the stupid manual ****. Just gonna have to get reverse threads in the **** to hold it on so its not sitting there
#308
I saw the auto ****, and thought it was kinda cool. It sure is different. I need to find an Integra cluster and vss so I can do the swap. I think they look much better than ef clusters.
#309
Using an old switch I fabricated a spring loaded switch for my glovebox. It is welded to the metal of the dashboard so that is one ground and then I have it grounded to a light so when I close the glovebox it breaks ground causing the light to shut off. Then when the glovebox is opened the ground circuit is completed causing the light to turn on.
welded the switch to the glovebox "guard" (the metal that catches the glovebox when it opens)
partially reinstalled
completely installed with exception to the wiring
#310
GSR gauges to replace the auto ls gauges.
wired up my own door ajar light so if any of the 4 doors is open it warns me. its the far right light above the fuel gauge
Also if anyone noticed, I got rid of the 88-89 hazard switch and wired up the 90-91 switch
#312
the hazard button is definitely cleaner looking too. Just can figure out how to figure out how to wire it up in my car to light up the hazard symbol. I have ideas but not sure I want to cut into existing wires and find out its a fail
#314
how did you get the hazard switch to light up? and just in case ur talking about something different I mean the button itself isnt lighting when depressed. It sows up on the gauges tho
#315
there were more than 1 power wires on the cluster i think i just followed d16sihatch diagram. it works for 88-89 tooo
#316
picked up a B18b1 today for the rest of the engine parts, gonna sell the rest of the engine. this is the integra I was originally gonna buy for the engine
#318
was gonna buy the whole car for $500 which is mad cheap, take everything off it and give him the teg shell back, then sell all the stuff I dont need. I still gotta go down and get the rear disc trailing arms, exhaust, seatbelts and ****. only charged me $250 for the engine.
#319
went to the junkyard to look for some obd0 stuff but no dizzy or ecu to be found. Picked this up instead
near new emblems
rt4wd bumper light
near new emblems
rt4wd bumper light
#322
the bumper light is just sitting there for the picture.
I just broke one of the foglight lenses
