Exhaust Manifold Torque Spec
Old 10-06-2010, 04:12 AM
selbher's Avatar
Icon2 Exhaust Manifold Torque Spec
1998 Accord LE 2.3 Liter In Line 4 Cyl.
I have leak in the gasket which I understand ***might*** throw a P0420 Bank 1 code. Should I tighten the bolts near the leak , reset the PCM and see what happens or altogether replace the gasket? If the latter option, what is the torque on the eight manifold bolts. Chilton does not say...
Thanks!
Old 10-06-2010, 02:49 PM
nus_dogg's Avatar
Default Re: Exhaust Manifold Torque Spec
Tighten them starting from the middle and work your way out. All Data software says 23 ft lbs. I would check the surface of the exhaust manifold and the mating surface on the head using a precision straight edge in case the manifold is warp.
ODbuilt
11-23-2013 07:03 PM
AmericanPie
01-01-2011 01:56 PM
dballard
Honda Civic (2006 - 2015)
01-18-2008 07:32 AM
phantomcow2
07-30-2007 05:36 PM
Quick Reply: Exhaust Manifold Torque Spec
