Key stuck in ignition
Old 08-24-2010, 12:04 PM
jcivic96's Avatar
Default Key stuck in ignition
My key keeps getting stuck in the ignition after I shut the car off? Anyone have any thoughts what the problem could be??
Old 08-24-2010, 12:38 PM
joe_accord23's Avatar
Default Re: Key stuck in ignition
push key in and turn counter clockwise.
Old 08-24-2010, 12:48 PM
He knows where you live!
TheMuffinMan's Avatar
Kind of an *** remark....
The steering wheel if locked can prevent the key from moving, try jiggling the steering wheel while doing it. Alternatively if you are cocking the steering wheel til it locks before removing the key it can cause issues.
Old 08-24-2010, 12:49 PM
Stage 3 CLINGER!
singlecamslamed's Avatar
My old 94 Accord used to do this. VERY irritating. I ended up just getting a new ignition. Fixed the problem.
Old 08-24-2010, 12:56 PM
oh no i didnt mean this in a bad way, u see, when i bought my first honda, i couldnt get the key out, called the friend who sold it to me and told me this. there is also that steering wheel technique u mentioned.
Old 08-24-2010, 02:01 PM
slamstrom's Avatar
Is the stuck key an OEM key or an after market key? Is this the first time using this key? Some non-OEM keys may not index correctly (it happened to me). The key body is not far enough away from the first notch on the key, and I was not able to push the key in far enough to disengage from the ignition lock. I had to use a dremel to cut a chamfer on the key body (by the shank). This allow me to push the key in further to disengage from the ignition. Good luck.
Old 08-24-2010, 03:29 PM
45js45's Avatar
is the key out?
Old 08-24-2010, 03:34 PM
Haha, it's all good.
I took it as "Just turn it idiot"
Old 08-24-2010, 04:33 PM
jcivic96's Avatar
The key is able to turn just when I try to remove it it get stuck...I comes out after a few minutes of moving it around. The is stock with the remote on it and it also happens when I use the valet key. I just found out though that there is a recall on it so that good to know
jackl04
10-05-2021 03:09 PM
maryk2121
06-25-2013 11:35 AM
ahloung
03-05-2006 01:34 PM
dc2go
05-23-2005 10:33 AM
XplodeTeg
10-26-2004 03:52 PM
Quick Reply: Key stuck in ignition
