Acura MDX / RDX
Odyssey Build: JDM StyleWagon Content
Old 09-11-2012, 06:05 PM
  #176
SirProject's Avatar
Default Re: Odyssey Build: JDM StyleWagon Content
wow...nice work i must say
Old 09-13-2012, 04:51 PM
  #177
gentek1145's Avatar
Flipped the motor and pulled the oil pump, oil bridge etc. to add on the KS Tuned balance shaft eliminator kit. The kit fits really well and looks awesome.
I also replaced all of the oil pump seals, crank seal, and waterpump.
water pump in/out
bottom end torn down for the bs removal
KS Tuned BS kit installed! Thanks KS Tuned!
Old 09-19-2012, 04:37 PM
  #178
gentek1145's Avatar
Almost done!
The H23A Blue Top is now a Green Top...Decided to get a different color on top, so went with a Candy Teal...and of course the blue Greddy belts!
Old 10-01-2012, 05:14 PM
  #179
gentek1145's Avatar
Back from powdercoating...
Flat blacked out the Intake manifold, AC bracket, PS bracket, Alt bracket, Motor mount bracket...and working on porting the runners on the IM as we speak.
Old 10-02-2012, 08:21 PM
  #180
gentek1145's Avatar
Blacked-out manifold + AEM Fuel Rail + AEM FPR testfitting...
Oh, and for a bit of bling, carbon kevlar wire cover, skunk2 oil cap, skunk2 vtec cover & blue NGK wires
Old 10-05-2012, 06:17 PM
  #181
gentek1145's Avatar
Had some issues getting the AEM Fuel Rail to fit this JDM intake manifold but we eventually solved the issue. Not too many JDM H23As running an AEM Rail that I could find online...
Installed the AEM Adjustable Regulator, and added a B&M Pressure Gauge so we can tune it when its running. For kicks, we're also doing the allen bolts on the manifold plenum, thermal intake manifold gasket, thermal throttle body gasket + port-matching the plenum to 70mm for the Skunk2 Alpha throttle body (and allen bolts for that as well...) These small details should provide a nice 10-12WHP bump over stock...
Old 10-14-2012, 06:24 PM
  #182
gentek1145's Avatar
With the help of a few friends, we pulled the motor out in a quick 2.5 hours, and started planning out the wire tuck & shave.
We had a bit of time today to start pulling the wire harnesses, mapping out which ones to extend / re-route, and brackets we'll have to fab. Once all the wiring is done, I can weld up all the extra holes and prep it for repaint.
Quite possibly the first Odyssey with a wire tucked/shaved engine bay?
Old motor is out!
Full wire tuck! No wires, No Fusebox, No Abs Fusebox, no more clutter!
Old 10-16-2012, 08:18 PM
  #183
gentek1145's Avatar
Welded 21 Holes today...after about 8 hours LOL. Weld, Grind, Weld, Grind...About 50 more to go! Then we can start sanding & primer. the FIRST ODYSSEY with a WIRE-TUCK & SHAVE Ever!!! SCW Performance +1
Old 10-17-2012, 06:08 AM
  #184
noeticnormy's Avatar
Good work sir
Old 10-19-2012, 08:17 PM
  #185
gentek1145's Avatar
Wire Tuck & Shave Odyssey after day 5, about 70 hours into it...Now we're at the filling stage and only the best EverCoat!
Stay tuned, gets paint tomorrow!
Old 10-20-2012, 02:04 PM
  #186
gentek1145's Avatar
Paint is on! Once its cure I can get it wetsanded & polished...
All in all, about 100 +/- holes were deleted, all seams were welded + smoothed out for a clean look
Check out that smooth pearly finish
Old 10-22-2012, 05:30 PM
  #187
gentek1145's Avatar
And new wheels came in today from my newest sponsor, Rohana Wheels!
These are the RC10 Rohana Luxury Wheels - 20x9 & 20x10 with Black / Machine Finish
Now just need to play with some camber and tire sizes for a perfect fitment.
Old 10-30-2012, 04:00 PM
  #188
allbwell's Avatar
That leather seating is beautiful. Is Garson totally 'out of catalogue' or do they do custom from drawings?
Old 11-07-2012, 04:15 AM
  #189
scottdh20's Avatar
looking great...ive been watching this build for along time...
pull the screws out of the alpha tb butterfly and lock tite them. if you do some searching online you will see several people had problems with that comming loose and getting sucked into the motor.
Old 11-08-2012, 04:11 PM
  #190
gentek1145's Avatar
A FEW pictures I took from SEMA SHOW 2012, and the VIP Car Festival in San Diego, CA...
New Wheels from Rohana - 20" Staggered - Cusco Camber Arms / Cusco Toe Arms
and some shots of the freshly built H23A DOHC VTEC (Blue Top) engine w/ custom mounts. The engine bay is fully tucked & shaved. Just waiting on a few fittings to finish up the power steering & a/c systems.
Old 11-09-2012, 07:16 AM
  #191
bigbpatel's Avatar
SICK car man! so damn clean.
Old 11-09-2012, 09:34 AM
  #192
theDesigner's Avatar
Might I interject and make a suggestion?
Old 11-09-2012, 12:43 PM
  #193
patburns101's Avatar
WOAH, thats a ill.
Old 11-09-2012, 04:28 PM
  #194
gentek1145's Avatar
Here's a closeup of the rears..
20x10 Wheels / Cusco Camber Arms & Toe Arms - Set to -6 Camber (current)
Old 11-09-2012, 09:26 PM
  #195
Sanji
toyomatt84's Avatar
Nice work in the engine bay!
Old 11-10-2012, 06:45 PM
  #196
gentek1145's Avatar
Its crazy looking at this before & after...
F22 VS H23A...
Old 11-11-2012, 09:59 AM
  #197
Sanji
toyomatt84's Avatar
Crazy in a good way.
Old 11-13-2012, 08:30 AM
  #198
Do you feel like the grill's edges do not flow with the body lines of the hood/side-panel and aftermarket bumper? I mean specifically, the angle of the grill hints at a more aggressive/sharper body style.
Instead, I see the grill's final bar (on the bottom) dipping it's center apex into the front-end which looks really awkward. It feels non-committal.
The grill simply doesn't fit the rest of the body lines. Just from my design-eye, I would recommend changing the grill to suit the contours of the rest of the body for a fitted and polished look.
Old 11-27-2012, 03:04 PM
  #199
OdManOut's Avatar
not really into the vip/garson style. but the van is sick. the new set of wheels are a lot nicer than the old set. engine bay is ridiculous. nice **** yak.
Old 11-27-2012, 06:01 PM
  #200
gentek1145's Avatar
Thanks man, I appreciate it.
I wasn't really into vans until I started to make some headway on my own. Its all people talk about here lately with this one leading the pack...
Quick Reply: Odyssey Build: JDM StyleWagon Content
