'97 Accord Rear Brake Line/Fitting Size
Old 07-30-2010, 02:55 PM
civicflow's Avatar
Default '97 Accord Rear Brake Line/Fitting Size
I am working on a buddies 97 4 door Accord and need to know the brake line size(diameter) and what size fittings Honda uses? I am going to replace both rear brake lines.
Old 07-30-2010, 07:51 PM
civicflow's Avatar
Default Re: '97 Accord Rear Brake Line/Fitting Size
Anybody know what size I need to order for tubing and fittings?
Old 07-30-2010, 10:12 PM
civicflow's Avatar
I am looking to replace both rear hard lines.
Old 07-30-2010, 11:49 PM
MM Gruppe B
MAD_MIKE's Avatar
I think the lines are 5mm and the fittings are 10mm. Possibly ISO bubble flares too.
Which lines exactly?
'97 4dr DX brake lines '97 4dr EX brake lines
The rear most stubby lines are only about 10 bucks each. While the main rear run #4 is about 90 green backs. May be worth it to just purchase and replace.
Old 07-31-2010, 01:14 AM
civicflow's Avatar
I am looking to replace 4 and 6. Looking to bend my own lines, especially since the passenger side line runs almost on top of the gas tank(which will be a pain in the *** to replace). Just gonna run a line around all that.
Anyone know what to order for the size of the line and fittings?
I know a 10mm wrench fits on the fittings but not sure if they are actually considered a 10mm fitting when ordering......?
Old 08-01-2010, 05:24 AM
poorman212's Avatar
Pull it off and visit your local parts store? Just a suggestion if you are going to bend it yourself. They do stock those, at least a good store would.
bluedragon
Suspension & Brakes
03-30-2017 05:11 PM
TXGrunt
01-14-2011 10:05 AM
civicflow
Suspension & Brakes
07-30-2010 10:11 PM
snouka
05-31-2008 02:08 PM
ion_four
03-22-2004 05:21 PM
Quick Reply: '97 Accord Rear Brake Line/Fitting Size
