how do you know if you have a bad wheel bearing?
Old 07-29-2010, 05:16 AM
JDMcivic801's Avatar
Default how do you know if you have a bad wheel bearing?
i have a ej1 and when i drive it, it makes a weird thumping/vibrating sound. could anyone tell me if this is my wheel bearing? thanks in adavance
Old 07-29-2010, 05:23 AM
fv8s's Avatar
Default Re: how do you know if you have a bad wheel bearing?
a wheel bearing sounds like a humming/ vibrating sound so that can possibly be it. if you had a video or something to reference we could help more
Old 07-29-2010, 05:49 AM
doneking's Avatar
Check your tires on the side that it sounds like it's coming from. inspect them for separated tread, thrown weights, and bulges in the sidewalls or tread area.
Usually if there is thumping and vibration the cause can be.
* Tires out of balance (Thrown weight, etc.)
* Tires are unevenly wore (Not rotated regularly.)
* Out of alignment
I've just recently acquired a '99 Civic and I'm going through it getting things in order. Mine sounds like I'm rollin' on Buckshot Mudders. From the wear on my tires, I believe it is improper inflation and rotation and my tires are roaring.
DK
Old 07-29-2010, 05:52 AM
BlueIntegraBoy's Avatar
You'll get a humming sound. Jack up the car and if you can wiggle your tire, your bearings are bad.
Old 07-29-2010, 05:55 AM
Former User's Avatar
It's often described as a groaning or growling sound that gets louder with higher speed.
Old 07-30-2010, 09:37 AM
thanks guys ill check these all out
Old 07-30-2010, 10:04 AM
HT Order of Merit
JDM_Ej's Avatar
They are pretty common to go. I could tell mine were because the front wheel(s) would shake at highway speeds.... badly lol.
Old 07-30-2010, 10:56 AM
brett304's Avatar
also, when the car is jacked up, you can turn the tire and if the bearing is fairly bad, you will hear it making a grinding sound...
streetglow116
04-17-2009 08:57 AM
honda_k20a
12-18-2008 05:25 AM
clippernabeel
Honda Civic (2001 - 2005)
03-30-2007 06:49 AM
nusdogg
04-10-2005 04:36 PM
crxtreme27
10-03-2003 02:58 PM
Quick Reply: how do you know if you have a bad wheel bearing?
