| Welcome to Honda-Tech! | ||
#1 |
1992 Honda Civic |
95 civic with a d15b vtec swap, my CEL light comes on when i crank my car. I jump off the CEL light to flash codes and the CEL just stays steady with no blink and the SRS light starts to blink... kinda weird guys!! someone said i could just unplug the SRS light form the cluster and it would ignore the SRS system and then flash my codes on the cel light.
#2 |
I got the same srs issue as you, hope someone gets back with a clarification. Im in a 98 CRV.
#3 |
its worth a try, dont leave it disconnected though cuz if u get in a accident ur bags wont deploy
#4 |
Moderator
2000 Honda CivicMy Garage |
You have CEL code 0. See CEL sticky at the top.
Does the engine start and run?
Don't guess, troubleshoot --------------------------------------------------------- Useful tech links: FAQs; Codes; Check Spark; Test Fuses; Fuse 15 TSB; Clean IACV or FITV --------------------------------------------------------- Please don't PM me tech questions. Create a thread. |
#5 |
Cell code 0? I got a 55 from my SRS light. Is this called the "S" light also?
#6 |
1995 Honda Civic |
I have the same issue with my at. : 95 civic 16z6: it sputtered and died and had no spark bit Now it's doing the same: CEL stays on, SRS flashes same intervals forever. What's the issue? Distributor?
| Tags |
| 95, 98, accord, blinking, cel, check, civic, engibe, flashing, flickering, honda, light, prelude, solid, srs |
