torque spec for civic single cam oil pan?
Old 06-28-2010, 12:03 PM
mengo911's Avatar
Default torque spec for civic single cam oil pan?
i want to know the torque spec for a single cam oil pan bolt????
mengo911 is offline
Old 06-28-2010, 03:04 PM
mengo911's Avatar
Default Re: torque spec for civic single cam oil pan?
anybody know?????
mengo911 is offline
Old 06-28-2010, 03:09 PM
Jdmglenn's Avatar
i like its like 10ft lbs per bolt right?
Jdmglenn is offline
Old 06-28-2010, 03:10 PM
Jdmglenn's Avatar
correction 8 ft lbs. dont over tighten
Jdmglenn is offline
Old 06-28-2010, 04:56 PM
mortificationrock's Avatar
**** my Haynes manual says- Oil Pan-to-engine bolts-120in-lbs.
^^WTF?
mortificationrock is offline
Old 06-28-2010, 05:20 PM
95EG2's Avatar
^^WTF?
WHAT???? THAT CRAZY DONT DO THAT IT 8 OR 9 FT/LBS
95EG2 is offline
Old 06-28-2010, 05:23 PM
95EG2's Avatar
NVM on my last post i though u wrote 120 ft/lbs...LOL... hayne manual is right 120 in/lbs is converted to 10 ft/lbs
95EG2 is offline
Old 06-28-2010, 05:32 PM
^^yup...i just noticed that too..LoL. So yeah its 10lbs
Old 06-28-2010, 05:36 PM
Former User's Avatar
8.7 ft-lb
The bolts must be tightened in at least three passes and in the correct sequence.
Former User is offline
Old 06-28-2010, 05:40 PM
Well i got mine from a haynes manual. So unless it says 8.7ft-lb in a HONDA manual then i go by the book.
Old 06-28-2010, 05:48 PM
My torque number was taken from the Honda Civic service manual.
Old 06-28-2010, 06:00 PM
Ok..what ever works i guess.
Old 06-28-2010, 06:39 PM
10 ft-lbs may be fine, not sure. I just wanted to post the number from the service manual and to mention that tightening the bolts in the correct sequence in several passes is critical.
Old 05-23-2014, 10:33 AM
Gvonbargen's Avatar
Does anyone know the sequence?? Or have a link to the sequence? Need to finish oil pan gasket repair
Gvonbargen is offline
Old 05-23-2014, 12:25 PM
Hysterically Calm
TomCat39's Avatar
92-95 Oil Pan D15B7, D15B8, D15Z1 and D16Z6:
Name:  92-95 oil pan.JPG
96-00 Oil Pan D16Y5, D16Y8, B16A2 and D16Y7 all use this method for torque:
What differs between the D16Y5/D16Y8 vs D16Y7/B16A2 is how much and where you put the gasket maker.
TomCat39 is offline
Old 05-24-2014, 12:15 AM
driguy's Avatar
Protip: If the gasket protrudes out from in between the bottom of the oil pan and the block, the pan is on too tight.
I torqued mine down to 8.7 and it bent the pan, gasket pooched out, etc. I did this with 2 different pans, then on the 3rd one I tightened up the bolts enough so the gasket was not visible. Haven't had a drop leak since.
This is on a D15b7 so I can't comment on any other engine, this is simply my experience.
driguy is offline
Old 05-24-2014, 09:22 AM
Hysterically Calm
TomCat39's Avatar
I believe you need a new torque wrench or get yours calibrated, 8.7 ft-lbs is very little torque and would not bend the steel oil pan of the D15B7.
I did mine to 10 ft-lbs with an extension and it's been a champ since. (Extensions reduce torque).
If you were bending your pan, then it was waaaay higher than 9 ft-lbs.
TomCat39 is offline
Old 05-24-2014, 10:12 PM
driguy's Avatar
I used a Harbor Freight 1/4" torque wrench with an extension. It's probable that I got one that wasn't good to begin with. I never had a problem with any of their other size torque wrenches but I believe I got a dud if that's the case.
driguy is offline
Old 05-25-2014, 05:39 AM
I never narc'd on nobody!
NotARaCist's Avatar
You used a precision tool from Harbor Freight. That's your problem.
NotARaCist is offline
Old 05-25-2014, 06:29 AM
Could also be user error.
Old 05-26-2014, 02:35 AM
driguy's Avatar
I'm going to agree with you on this one. That particular torque wrench (and the other ones they sell, why mince words) has various issues. Most of them stemming from the fact that HF tools are, by and large, pieces of ****.
driguy is offline
Old 05-26-2014, 02:57 AM
The Grumpiest
grumblemarc's Avatar
This is most likely your problem.
I bough a T-wrench from Autozone a while back and now that summer's here and I want to build my spare block, I'm scared to use it. Just going to get a Snap-on for piece of mind.
grumblemarc is offline
Old 05-27-2014, 06:25 PM
NotARaCist's Avatar
FWIW, I absolutely love using my step-brother's Snap-On torque wrench. It's a clicker type, and I'm fairly sure that it's touched every nut and bolt on my engine at least once.
Old 05-27-2014, 10:16 PM
Hysterically Calm
TomCat39's Avatar
Even Snap-On's should be calibrated quarterly or monthly in a shop setting depending on business.
Home use, probably 6 months to a year is a more typical wrench maintenance schedule.
TomCat39 is offline
Old 04-15-2019, 08:44 PM
elshakankiry1's Avatar
i think 9 lbs
elshakankiry1 is offline
DCtito
06-09-2006 05:22 AM
9 CRX si 1
05-20-2006 11:50 AM
3s0n3
02-12-2006 08:22 AM
siis2fast
06-30-2005 02:31 AM
prjctCIVIC
09-01-2001 09:53 PM
Quick Reply: torque spec for civic single cam oil pan?
