gas leaking from evap canister?
Old 06-23-2010, 03:09 PM
jon123's Avatar
Default gas leaking from evap canister?
I have a engine light on for evap system leak. I noticed gas leaking from the canister drain tube? Is this normal when the canister is toast? Or is there some other problem? I removed the two vacuum lines going to the canister to see if fuel is come in from there but they were dry.
The car is a 95 accord ex. Any info would help. Thanks
Old 06-24-2010, 05:33 AM
sgraham01's Avatar
Default Re: gas leaking from evap canister?
if i had to guess, maybe it's not purging the vapors as it should and they are building up and condensing in the canister. I think there should be a purge solenoid that may be need to be tested out.
Old 06-30-2010, 06:46 AM
90_civic_Si's Avatar
So have found some info on removing the canister all together. Do i just plug the line from the tank and remove the canister?
Old 06-30-2010, 06:57 AM
sgraham01's Avatar
I suppose you could do that since it's OBDI, but I have never done that. Your mileage may suffer some, but I can't tell you for sure. I would diagnose it properly and repair the problem before removing it. test out the purge solenoid and see if it's bad. Maybe that will fix everything.
Old 06-30-2010, 07:05 AM
Which one is the purge? The one on the tank or the one by the canister?
Old 06-30-2010, 07:26 AM
sgraham01's Avatar
purge solenoid is number 5 in diagram. this is for a 94 lx. i guess number 6 is the solenoid for the ex model...?
RussBarnes
03-22-2015 03:36 PM
pei_kid
03-16-2013 03:53 AM
VTEC_Viking
07-30-2008 09:33 AM
Jay.D.Em!
16
01-30-2006 04:31 PM
BlazeTeck2000
11-22-2005 04:12 PM
Quick Reply: gas leaking from evap canister?
