96 honda accord computer resets every time car turns off
Old 06-15-2010, 11:01 PM
blackiceboi's Avatar
Post 96 honda accord computer resets every time car turns off
So this is my first post any help would be greatly appreciated
I have a 96 honda accord ex 4door 2.2L engine
I have tried multiple times to have my car pass emissions
each time 4 sensors have been found not ready...
EVAP EGR Catalyst O2 Sensor
The mechanics at the emissions place tested my car and found that every time i turn my car off the voltage of the battery gets dropped to 0 and when started up the voltage returns...i need to pass emissions and have driven over 400 miles to get sensors ready...
The concept is that every time i turn my car off it resets my car computers monitors and sensors therefore i cant pass emissions
CAN ANYONE HELP
Old 06-16-2010, 01:10 AM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: 96 honda accord computer resets every time car turns off
First off I'll admit I am not familiar with the '96 OBDII system. With that said...
Is there a fuse for the ECM memory? If so could it be blown/missing causing this issue? My crapshot theory is without memory power the ECM, obviously, loses memory and resets when turned back on. Although with OBD II I would think that the system would monitor for such a critical error and set a hard fault code immediatly.
Like an older game/arcade system, it works fine all day long but as soon as its turned off all those high scores are cleared.
Old 06-16-2010, 04:44 AM
GhostAccord's Avatar
Check the back-up fuse under the hood.
Old 06-16-2010, 06:57 PM
which fuse would it be?
Old 06-16-2010, 07:24 PM
If I remember correctly it's labeled Back-Up. It's a 7.5amp fuse.
Old 06-16-2010, 07:25 PM
Does your radio keep resetting as well?
Old 06-16-2010, 07:43 PM
no the radio presets stay but i do have the clock resetting issue but i dont think that has to do with why i cant pass emissions
Old 06-16-2010, 10:06 PM
Dannyvho's Avatar
That makes sense: the ECU memory and the clock share the same fuse. Like Ghostaccord said: replace the 7,5A fuse. Hopefully there's no problem with the electric circuit causing the fuse to blow.
Old 06-16-2010, 10:22 PM
well the person who had the car before me i guess had cut the radio harness and put in an aftermarket and when i got it back i had to buy a factory harness from ebay and hook the factory radio back up but there are 2 wires that i assume are for the clock that i dont know where to hook up
Old 06-16-2010, 10:35 PM
phootbag's Avatar
I always wondered why the ECU never had an internal power supply like the SRS unit.
As stated, check the backup fuse.
Old 06-16-2010, 11:35 PM
checked the fuses everything no fuses are blown no change
Old 06-17-2010, 12:00 AM
Do you have a multimeter & are you familiar with electrical troubleshooting?
With the car turned off. Measure the voltage @ fuse No.1 (Back-up) You should see battery voltage. Then measure the voltage at the ECU pin C10 (WHT/YEL wire), You should also battery voltage at the ECU. The ECU is located in the passenger footwell under the carpet. If you don't see battery voltage at one of these spots you will know that there is an open/short in that section of the wire.
Old 10-05-2013, 01:40 PM
LRey Baez's Avatar
I'm having exactly the same problem, did you ever find out what it was that was causing this problem?
Old 10-05-2013, 04:14 PM
MM Gruppe B
MAD_MIKE's Avatar
Have you checked the 7.5 Fuse? Just because it may look good does not mean it conducts, test it. Have you checked for voltage at those terminals? Have you checked for memory voltage at the ECU connector?
What have you done so far?
Old 10-05-2013, 11:05 PM
holmesnmanny's Avatar
The car won't start with the 7.5 radio/backup fuse blown.
Old 10-06-2013, 12:00 AM
wolfy47's Avatar
There is a ECU fuse in the underhood fuse box. Although if it were blown the car would not start at all (Back when I had a 5th gen I would remove the fuse to reset the ECU or to try and prevent the car from being stolen in bad areas).
Old 10-06-2013, 02:18 AM
yep i do that as well
Old 10-07-2013, 04:27 AM
LRey Baez's Avatar
I had originally looked at all fuses and thought that the back up fuse was good. However upon closer inspection, the # 7.5 backup fuse was blown even though it lot up on one side. I turned my car on and off and the stereo has kept the time , fault codes are fine now, I'm going to run it to give the monitors time to test, then ill smog it today. Thanks for all your help with this tread.
Old 10-07-2013, 08:22 PM
LRey Baez's Avatar
My car passed smog, thanks for your help.
angel247
12-27-2013 10:50 AM
kcurtis61
03-17-2007 03:43 AM
TylerW
10-22-2006 03:47 PM
Quick Reply: 96 honda accord computer resets every time car turns off
