What did you do to your integra today?
Alright guys, its just like the guys have on the civic forums, but for us. There are rules that apply. They are:
1. If you are going post, it should have you with a completed task. You can also put down the amount of time it took.
2. Keep it technical.
3. Keep it clean.
4. Any questions for another member, must go thru PM.
Mods will be watching this so lets get this started.
What I did to my integra today:
I installed a modified B16 IM to my P8R head. I also swapped out my head gasket. 10 hrs
3. Keep it clean.
Re: What did you do to your integra today?
Let's see, I made my double din block off plate template using the particle board from the spare tire cover. Currently holds 2 gauges. And I went and picked up my coil over sleeves from the local speed shop. oh, I also put in a qt of oil......
Old Fart
Had my buddy Jim look at the new paint, he did a little polish and applied some wax just to protect the finish, he wants to do a clay bar, light cut and polish and a couple coats of wax next week.
I removed duct tape residue left behind from having plastic taped over rear side window openings, windows go in on Monday.
I pulled the front clip to install mesh, ["expanded" aluminum] and do a little "tweaking" to mount the clip a little better.
I installed the rear side windows inside trim and seat belts, [driving car again after 2 years].
Spent 1hr looking for the front license plate and stock rear pass. speaker housing, still lost.
Cleaned 2 years of dust and crap off the rear inside trim paneling, [stored in shed for 2 years].
Took some pix, will put them up later.
All the above and I still got to watch F1 qualifying. 94
oil change
scratched sanded and spray bombed some floorboard rust
found a rubber ring that i believe is part of the intake tube
changed the oil in my buddy's rsx
wondered why the filter is directly above the axle
cleaned oil off rsx axle
I shredded my new altenator belt with my a/c belt due to the fact that the head of the bolt on the a/c tensoner snapped off and left my a/c belt lose to go anywhere
i installed double din bluetooth pioneer stereo (about 45 mins) now i have to figure out were my car is leaking coolant from...
Washed, Clay bared, Scratched X, waxed. Polished exhaust and rims with blue magic also adding two coats of tire wet. ~ 9 hours minus 30 mins for lunch break.... Yah im eat up
did a oil change after 5months of daily driving
and bought the missing LS mesh rim, so i finally have all four rims on now
painted ek sideskirts, DA fronts, and EF rear flaps......next side mirrors front lip and moldings
oh and did valve adjustment too. 3 to 4 hours
rebuilt power steering pump on my 91 da and washed it. Buffed the hood(carbon fiber hood) on my 96 dc2 to get out the water spots they wur really bad. You could hardly tell it was a carbon fiber hood well not that bad but u get my point, it took about 3 hours but it looks new again.
Oil Change, Tire rotation, Steam cleaned the inside with a Bissel and carpet cleaner but came out nothing like the one above... too many stains from previous owner...Installed a B&M short throw with a friend. That was within the last week
i blew my head gasket!
it took me 5 mins after i left my house!
now i have to find out why someone sliced my lower coolant hose so i would overheat my **** last night
maybe consider quittin the 420 thing so i pay attention to my temp a lil more..... naaaaah lol
